Other Stuff
The Blue Oyster bar
Africa Twin noise..
Pages:
3
Topic: Africa Twin noise.. (Read 5233 times)
Hugo Magnus
Bike: DL650A L3, DR-Z400s Multistrada 1260ST
Re: Africa Twin noise..
Reply #20 on:
September 07, 2018, 12:35:46 »
All that Snowfoam has degreased the bearing- now it's disintegrated.
The interruptions ARE the journey (Ted Simon)
kwackboy
Reply #21 on:
September 07, 2018, 15:24:01 »
Ridaz
Site Donator
Bike: Africa Twin 2017, TTR 250 2004, VF 750F-D Interceptor 1983
Reply #22 on:
September 07, 2018, 15:41:09 »
Andy someone just posted this video on the CRF1000 Africa Twin group. Some movement in the front sprocket but not enough to to justify the noise yours is making.
(You will need to be logged into Facebook and select watch on Facebook)
Getting mostly comments of they all do that sir but one suggestion of worn splines?
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #23 on:
September 07, 2018, 16:30:17 »
Thanks, the bike has only done 6000 miles
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #24 on:
September 07, 2018, 16:40:43 »
I am not going to mess around with it, it is under warranty so back to the dealers it goes.
Visit the
V-Strom.co.uk shop
today!
Asmith61
Bike: 2011 B-King 1300 , 2023 Harley Nightster 975
Reply #25 on:
September 07, 2018, 18:02:54 »
That ain't right boy I agree take it back
Griff2
Bike: DL1000 L6
Reply #26 on:
September 07, 2018, 21:17:59 »
Just curious what type of chain lube do You use ?
Griff2
Bike: DL1000 L6
Reply #27 on:
September 11, 2018, 11:41:09 »
Any update on the noise ?
ggreen1959
Bike: DL650 K5, 1998 VTR Firestorm, 1977 RD250D
Reply #28 on:
September 11, 2018, 14:08:40 »
Almost sounds like the bearing cage has broken and your balls are rubbing together!
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #29 on:
September 11, 2018, 14:28:50 »
Sorry folks, work stopped play.
Well, if I slacken the chain (to the point of being too loose) the noise goes away. The chain looks to be in good order with no obvious tight spots, the bike has done less than 6k.
Visit the
V-Strom.co.uk shop
today!
kwackboy
Reply #30 on:
September 11, 2018, 14:59:24 »
I'm going to take a punt at the front sprocket . If It is I'm not sure your warranty will cover that as it's wear and tear but you could try .
Ianmc
Bike: DL650AL5
Reply #31 on:
September 11, 2018, 15:25:02 »
Can the front sprocket be turned around or is it offset.I did this on my Wee after about 14K miles on the current chain set to equalize wear on the front sprocket.Set has now done 16K and runs and looks like new.
Jack Meoff
Bike: 2015 Dl1000 Adventure
Reply #32 on:
September 11, 2018, 15:35:46 »
any chance of putting up a couple of pics of front and rear sprockets close up?
Griff2
Bike: DL1000 L6
Reply #33 on:
September 11, 2018, 21:45:13 »
Quote removed
I had one of these bikes and I have a vague recollection that I might have heard something similar from the chain during the 17,000kms of my ownership, albeit not as severe. My memory is hazy because I obviously didn't take it seriously. That is also a reason why I suggested dousing the chain with oil to see if the noise went away. On that bike I always ran the chain slack at the loosest end of the permitted slack and sometimes even looser than that.
My suggestion is that Your chain was too tight and also that there was not sufficient lube
under
the rollers. As such they were binding on their bushings and resisting rolling over the tips of the chain teeth and then clicking into the dip between the teeth. I am not suggesting that you are not lubing your chain but that many proprietary spray lubes don't get sufficiently under the rollers. That is why I put a line of good motor oil on the inside run of the chain after every spin and that oil gets well under the rollers while the chain is still hot and the bike lies up.
Just some thoughts.
ggreen1959
Reply #34 on:
October 14, 2018, 11:57:35 »
Any news on the noise?
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #35 on:
October 14, 2018, 11:59:29 »
Sorry, I thought I had updated this. It turns out that chain did have a tight spot, even though it wasn't visible
I was sceptical but a new chain and the noise is gone.
Visit the
V-Strom.co.uk shop
today!
Hugo Magnus
Reply #36 on:
October 14, 2018, 13:45:18 »
I was wrong
ggreen1959
Reply #37 on:
October 15, 2018, 14:14:41 »
My 'Wee' chain suddenly gave up, from adjusting correctly (play correct with weight on at tightest point) one day, to stretching beyond belief and coming off 2 days later!! Weird!
Griff2
Bike: DL1000 L6
Reply #38 on:
October 16, 2018, 12:43:02 »
I just noticed that my quote was removed above on my last comment. Just curious, what did I do wrong ?
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #39 on:
October 16, 2018, 12:54:42 »
Griff, you either quoted the post directly above
or the quote was unnecessary
Visit the
V-Strom.co.uk shop
today!
Pages:
3
Other Stuff
The Blue Oyster bar
Africa Twin noise..
