Author Topic: Africa Twin noise..  (Read 5235 times)
Africa Twin noise..
« on: September 06, 2018, 20:22:14 »
I have had the front sprocket cover off and I have checked that there isn't a playing card clothes pegged to the front wheel. Any suggestions what this noise is?
Online TLPower
Re: Africa Twin noise..
« Reply #1 on: September 06, 2018, 20:35:58 »
A woodpecker?
(You didn't mention a prize, but I assume there is one).
Offline Jack Meoff
  • Bike: 2015 Dl1000 Adventure
« Reply #2 on: September 06, 2018, 20:36:34 »
knackered sprocket
« Reply #3 on: September 06, 2018, 20:40:14 »
Has just appeared suddenly?  Have a look at the plastic chain guide on the swing arm pivot. Has it been damaged?
« Reply #4 on: September 06, 2018, 20:49:36 »
Strange.. !! If it made the noise only going backwards id say that was a hooked front sprocket. Does sound front sprocket related though but could be wrong .
Offline Hugo Magnus
« Reply #5 on: September 06, 2018, 21:10:23 »
Bearing cracked up? The noise is your balls dropping :shock:
« Reply #6 on: September 06, 2018, 21:13:49 »
 :text-goodpost: good point , try looking at your rear sprocket hub bearing .
« Reply #7 on: September 06, 2018, 21:31:15 »
 lol
Sounds like a tight chain going over an out-of-alignment rear sprocket
Offline vstroppy
  • Bike: 2014 vstrom 650
« Reply #8 on: September 06, 2018, 22:25:56 »
Sounds like something is catching the ends of the rollers on the chain, could be something has gone down into the sprocket guard and is catching, or a crankcase screw has come loose and is catching the chain rollers.
Adventure before Dementia
« Reply #9 on: September 06, 2018, 22:29:25 »
There has been an issue with the AT's rear hub bearing highlighted on Honda Adventure Riders forum.
Something like Honda using shoddy bearings and Tai ladyboys putting the bikes together.  :shrug:
to be honest I wasn't paying much attention when I read it.
Offline wurzel
« Reply #10 on: September 06, 2018, 22:41:02 »
Sounds chain related but then again maybe not , try getting it up on a stand and turning the wheels independently maybe, and locate the sound with a bodged up stethascope,but of Hosepipe, or rest a metal rod between your ear and the rear hub.
Offline Griff2
  • Bike: DL1000 L6
« Reply #11 on: September 06, 2018, 22:44:36 »
Does a good lubing of the chain help ?  Also pull the sprocket cover off again and get some lube between the front sprocket and the splines of the countershaft. I have noticed that the splines can run dry on Hondas and rattle a bit on the ones with a floating front sprocket. Not sure if the CRF has a floater ?
If neither of the above sort it then I would look to the rear wheel bearings as suggested above.
Offline wurzel
« Reply #12 on: September 06, 2018, 22:48:11 »
Good call Griff,  worth greasing those spines on a floating sprocket too.
Online TLPower
« Reply #13 on: September 07, 2018, 05:35:23 »
A woodpecker aside, as others have said it does sound like a misaligned bearing. Stick it on the centre stand and spin the wheel of justice at least it will point you as to which (if either) the noise is coming from.
« Reply #14 on: September 07, 2018, 09:04:03 »
Have you got a chain oiler fitted and have adjusted the chain recently?
« Reply #15 on: September 07, 2018, 10:24:08 »
Thanks for your input folks (sorry, no prizes), the noise is definitely from the front sprocket/shaft bearing  :bawl:
Offline Ridaz
  • Site Donator
« Reply #16 on: September 07, 2018, 10:49:24 »
I've not seen anything similar mentioned in any of the Africa Twin forums Andy. Will keep a closer look though.
« Reply #17 on: September 07, 2018, 11:22:23 »
Blimey... that is so rare.  Never seen a front sprocket bearing fail on a Honda :shock:
loosen your chain, take your front sprocket off and re-check it.
Offline Griff2
  • Bike: DL1000 L6
« Reply #18 on: September 07, 2018, 11:50:40 »
Almost sounds like an overly tight chain. I would be very surprised if the countershaft bearing was gone. I have never seen one go on any bike no matter how tight the chain.
« Reply #19 on: September 07, 2018, 12:13:04 »
Does sound like a tight chain.
But I'd speak to your friendly local dealers and kick up a fuss.  :fix:  :icon_batterup:
