0 Members and 7 Guests are viewing this topic.
Small spacer at the bottom and a large spacer at the top and as Mick said the blade about an inch from the top
Mine is set on the middle setting and the top screen is about 1" above the lowest it will go.
@sjrainsfordTop holes used on mine, also afflicted with short legs, long body. I also have a Palmer products screen bracket for the Glee that fits a standard screen £35 +p+p
Actually mine is also using top holes, with the top of the screen just below my eye line... I have a Satnav mount using the middle holes - when using the Satnav above the instrument/clocks (whatever) it introduces more noise
Hello, I am not sure if my new screen is a Givi Airflow
