Author Topic: Cosmo centre stand.  (Read 1210 times)
Offline Dicky
  • Bike: DL650 K4
Cosmo centre stand.
« on: August 29, 2018, 05:31:39 »
Good morning,
I recently purchased and fitted a Cosmo centre stand to my 2004 DL650. I am very happy with the stand but there is one niggle. I can't now operate the side stand with my left foot when sat on the bike. I have to lean down and operate the side stand with my left hand as the stand catches on part of the centre stand. Has anybody else had this problem and how did you overcome it?
Thank you,
Dicky
Offline Metro Strommer
  • Bike: V Strom 650
Re: Cosmo centre stand.
« Reply #1 on: August 29, 2018, 11:25:06 »
A photo might help for members to see possible cause I fitted mine a couple of weeks back no problem and I get my side stand down no problem have you got all the spacers in the correct position.
Offline Dicky
  • Bike: DL650 K4
« Reply #2 on: August 29, 2018, 13:32:57 »
Thank you Metro Strommer,
I have just had another look at the setup. All spacers and nuts are correctly fitted. There is, however, free play at the pivot end of the side stand as if there might be a spacer or washer missing in the side stand assembly. Sadly I have no idea what the side stand assembly should look like where the side stand attaches to the frame.
Cheers,
Dicky
Offline user650
« Reply #3 on: August 29, 2018, 18:11:12 »
Do you have a side stand "foot" fitted?  They are known for catching, I have cut mine down slightly so it doesn't catch the centre stand now. :thumb:
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline Dicky
  • Bike: DL650 K4
« Reply #4 on: August 31, 2018, 05:44:06 »
Hi user650,
No I don't have a "foot" fitted. Just standard. Had a search on this site for side stand problems, particularly regarding the free play at the pivot end, and a few posters had confirmed that as "normal". I'll drop Cosmo a line once they are back off their hols and see if they have experience of my issue.
Cheers,
Dicky
Offline Dicky
  • Bike: DL650 K4
« Reply #5 on: September 01, 2018, 13:36:51 »
Had a chat with the blokes at Cosmo who suggested it was a side stand problem. Took the side stand off and one of the pivoting lugs was bent out of shape through misuse. Straightened said lug and closed the gap between the lugs a tad and everything now works fine. Excellent after sales service from Cosmo. :fix:
Cheers,
Dicky
Offline Outthereondartmoor
  • Bike: DL650
« Reply #6 on: September 01, 2018, 14:03:38 »
I fitted one on my 2017 650 and have no fouling issues.
I do have a problem getting the side stand off to fit the sump guard though! God only knows what the nuts ate torqued to.
