Author Topic: 'Vario' touring screen - too low for me - help please  (Read 2650 times)
Offline wilmot
« on: August 23, 2018, 15:42:49 »
Hi everyone, I have recently bought a DL650 (2012) and during early rides, the screen appears a bit low for me, I'm 5'10" and have to 'duck down' about 4 inches to cut out wind noise. I have adjusted the screen as far as I can and it's on the upper set of mounts.
Any suggestions please (I have seen the 'Palmer' stand alone screen mount at about £58 that appears to do the job of raising it a bit.
Thanks in advance, Andy
Offline hookie
Re: 'Vario' touring screen - too low for me - help please
« Reply #1 on: August 23, 2018, 17:24:44 »
It's often thought that the problem of wind buffeting with Vstroms (which has been going on for years) is caused by not having a tall enough screen. The near vertical screens on Vstroms  just creates an area of dead air behind it and a lot of turbulent air above and around the screen. Hence the awful buffeting if your lid is stuck in it. Changing the air flow over the screen is often a better solution as it improves the air flow and reduces the buffeting. One way of doing this is to tilt the screen backwards. You used to be able to buy an adjustable mount that did just this (but I can't remember the name of it, or whether it's still made for the latest Vstroms).  An alternative is to make up some packing pieces and possibly longer mounting bolts and fit these on the bottom mounts which tilts the screen back, if it can be done on your bike. I did this on my old Vee and it worked a treat. All I used was a couple of rubber tap washers and it was enough to alter the air flow sufficiently to eliminate the buffeting but still allowed useful air flow around my crash helmet. Worth a thought....
Offline pichulec
  • Bike: KTM 1290 SAS
« Reply #2 on: August 23, 2018, 17:43:29 »
Or use adjustable bracket :)
Offline wilmot
« Reply #3 on: August 23, 2018, 18:12:40 »
Hello, thanks blokes, I'll try the adjustment to the current screen and if that doesn't ease the situation, I'll buy the adjuster.
ATB, Andy
« Reply #4 on: August 23, 2018, 18:27:35 »
This is one of the brackets/screens you can get. Often 2nd hand, too, or from uk supplier cheaper
https://madstad.com/products/Suzuki-vstrom-650-2012-up
« Reply #5 on: August 23, 2018, 18:30:47 »
One thing to be aware of with a Madstad bracket on an L2 - you will also have to buy a new screen, which bumps the price. Screens made for the wee (2004 - 2011) will fit.
« Reply #6 on: August 23, 2018, 18:44:06 »
Really, Rusty? You mean if you put an L2 madstad on, then the older bike screens fit on?
Larn summat new every day!
« Reply #7 on: August 23, 2018, 19:01:33 »
The glee has the deep recessed holes in the screen, these don't line up with the screen mounts on the Madstad. It looks as if they half-designed the bracket for the glee, using a new base section to suit but marrying that to the original moving section, which is why wee/vee screens are needed.
« Reply #8 on: August 24, 2018, 11:38:13 »
 :thumb:  how strange...at least there's a good supply of cheapish screens for the wees
« Reply #9 on: August 24, 2018, 12:40:28 »
A Givi Airflow is the way forward  :thumb:
Offline Silverback
  • Bike: DL650 K7
« Reply #10 on: August 24, 2018, 18:27:01 »
I second the Givi Airflow, I'm 5'8" and get very little buffeting and wind noise even at high speed with screen at lowest setting....I can still see over the top.
Offline tdo
  • Bike: V-Strom DL1000A L6; BMW R nineT
« Reply #11 on: August 25, 2018, 11:18:27 »
Givi Airflow is the best add-on that you can mount on your L2-L6.
Reduces buffeting and noise quite effectively.
Hint: don't' mount it too high, you should still be able to see over the top.
Guideline: Mark a spot 10 meters before your bike on the road surface and try to see that spot when sitting normal on your bike without looking "through" the windscreen, but over it.
Offline user650
« Reply #12 on: August 29, 2018, 00:03:23 »
I have the palmer bracket for sale here
https://www.v-strom.co.uk/smf/index.php?topic=34238.0
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline wilmot
« Reply #13 on: September 04, 2018, 16:12:06 »
Right folks, this is what I did... the lower spacers on the screen were smaller than the upper ones, so I took them off, putting the larger ones (top ones) on the bottom, and also added (as suggested) a couple of tap washers, this seems to have made a difference to the buffering but not the wind noise, that I guess is from my helmet.
Cheers folks.
