Fork seals
Topic: Fork seals (Read 2187 times)
rayboy68
Bike: DL650 L2
Fork seals
August 16, 2018, 16:58:28 »
Hi blokes, it appears I have a seaping fork leg, looking for advice on the Best place to go for genuine seals, I have a local stealers by me but I was wondering if any of you know where else I can look ? Thanks
Gassoon
Quotes Museum Curator & Moderator
Bike: DL650X L7
Re: Fork seals
August 16, 2018, 17:27:48 »
One place could be 'Robinson's Foundry'. I think there's a forum discount, too,
HERE
if it's still operating.
The fork seals should be the same for your model as the 'vintage' ones they offer!
Fat Rat
Administrator
Bloke/Geezer/Fella
Re: Fork seals
August 16, 2018, 17:39:15 »
Have you tried running a thin piece of plastic around them to see if a piece of grit is causing the problem?
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
rayboy68
Bike: DL650 L2
Re: Fork seals
August 16, 2018, 18:00:59 »
Thanks lads, I've tried Robinson's but they don't list the L2 but I could cross reference the part numbers ????
Never even seen a seal mate but certainly worth trying, however I know the strom was on the side stand for a while and it just so happens to be the left leg. Thanks lads
Graham62
Bike: DL650 K6 Blue
Re: Fork seals
August 16, 2018, 18:02:52 »
+1 for seal mate.
Graham
Gassoon
Bike: DL650X L7
Re: Fork seals
Reply #5 on:
August 16, 2018, 18:23:57 »
This bloke made one! Confess I have never tried this fix myself at all, but plenty, like graham62, report that it works!
of course, mebbe the seal is properly knackered
rayboy68
Bike: DL650 L2
Re: Fork seals
Reply #6 on:
August 16, 2018, 18:57:37 »
The reviews on the seal mate are good so I've just ordered one off eBay £6.49 so its definitely worth a try at that money, watch this space Stromers for the result.
Fat Rat
Administrator
Bloke/Geezer/Fella
Re: Fork seals
Reply #7 on:
August 16, 2018, 20:17:00 »
I shall just want a reasonable fifty percent of the savings for new seals if it works
Visit the
V-Strom.co.uk shop
today!
Mr Nick
Certified Fisher Price trained technician
Bike: 1979 Suzuki TS185ER, 1979 Moto Guzzi V50, 1989 Moto Guzzi SP3, 2010 KTM 990 Adv
Re: Fork seals
Reply #8 on:
August 17, 2018, 00:41:19 »
A chunk of 35mm film used to work well, but harder to find these days & an SD card just isn't as good...
Orange Bikes Matter!
Leighmorgan
Live life to the full
Bike: DL1000, V-Strom 2016 and Husqvarna te450 2010
Re: Fork seals
Reply #9 on:
September 05, 2018, 20:10:28 »
Mine left one started leaking and only done 7000 so I replaced both sides. I've seen a few posts saying that the left side is leaking. I got a set off eBay not genuine ones.
rayboy68
Bike: DL650 L2
Re: Fork seals
Reply #10 on:
September 05, 2018, 23:08:10 »
It looks like I will have to replace mine as the seal mate didn't do the trick, when it comes to fork seals I only use genuine as I've found non oe seals have failed me in the past in such a short time.
UK_Vstrom650
Bike: DL650A L2
Re: Fork seals
Reply #11 on:
September 06, 2018, 09:20:54 »
I've changed mine twice now - first time last summer c.32,000 miles- homemade sealmate worked to pass the MOT but it started leaking not long after. I used non-OEM first time and had to replace them this summer as one started leaking again
. Have gone OEM this time as although they cost more, stripping the front end to change fork seals is a PITA.
rayboy68
Bike: DL650 L2
Re: Fork seals
Reply #12 on:
September 07, 2018, 21:58:52 »
All you Stromers that have changed your fork seals is it advisable to buy the kit or am I just OK to just change the seals, bikes only done 6k on a 12 plate.
UK_Vstrom650
Bike: DL650A L2
Re: Fork seals
Reply #13 on:
September 08, 2018, 06:18:38 »
I changed the oil and dust seals together.
Fork seals
