650 2010
Topic: 650 2010 (Read 937 times)
northern_southerner
Bike: DL650 L0
650 2010
July 25, 2018, 19:58:24 »
The link above is the multimeter reading from my v strom. Last night I noticed neutral light flickering, then today it wouldn't start. Would you blokes agree my stator is daffy ducked? Thanks
sjrainsford
Bike: DL650 L4 and 2008 Vespa GTS300 Super
Re: 650 2010
July 26, 2018, 07:49:23 »
Yep, alternator or regulator. Wiring has to be considered too. Easy fixes are always nicer!
northern_southerner
Bike: DL650 L0
Re: 650 2010
July 26, 2018, 21:57:23 »
Cheers for reply mate
I checked the regulator and it tested good, I then tested the stator and the first 2 test good but test that you run the bike and check current was bad on one of the connections.
northern_southerner
Bike: DL650 L0
Re: 650 2010
August 03, 2018, 21:47:13 »
Hello blokes, so I replaced my stator and started bike today, I got 12.2 when idling and 12.6 when 5000 rpm.
The rectifier tested OK when I checked it. could it be the battery? also a slight flicker in the side lights
thanks in advance
northern_southerner
Bike: DL650 L0
Re: 650 2010
August 04, 2018, 09:03:44 »
I ran the test of the 3 yellow wires from new stator, engine running at 4000 got 52 52 52.
tested rectifier got 0 0 0 then 632 632 632 then 632 632 632 and 0 0 0 on the last wire.
battery held charge all night 13v
anyone any idea's
650 2010
