To be fair infidel the hole centres for my 650 were dimensionally easy: 175mm apart at the top, 115mm apart at the bottom and 85mm apart vertically with the same dimensions for three different positions 25mm between each. They're not the same on your thou' of course but you can easily measure them from the screw positions without dismantling it?
Good luck!
