Author Topic: GEARING  (Read 1263 times)
Offline yanky192
  • Bike: DL650 L3
GEARING
« on: May 06, 2018, 09:41:15 »
Hi All. I am not great with threads so if I started one that is out there sorry too old to learn , I not long bought a 2013 650 and compared to some of my other bikes its miles better , the gearing is good enough for off road but I will not be doing that so has anyone went up 1 teeth on the front sprocket or down 1 or 2 on the back as when I am in  in 6th gear I am looking for another gear like my Versy,s this was common so I went up a teeth on the front and it lowered the revs in top gear and no problem pulling away and helped the fuel and got a few more mph for touring which is mostly what I bought the bike for as I have another bike for town riding , any help would be appreciated .
Offline wurzel
Re: GEARING
« Reply #1 on: May 06, 2018, 09:49:31 »
  I seem to remember others have gone up one on the front, that should give you all you need, and would be my first move.
  Try to get a high quality sprocket, preferably a Suzuki one if they are available.
Often sprockets are hardened all over, this can cause gearbox output shaft spline wear over time, so it is better if the sprocket wears at the splines rather than the shaft.
This is more of an issue with off road bikes, but is still applicable to road use.
Offline yanky192
  • Bike: DL650 L3
Re: GEARING
« Reply #2 on: May 06, 2018, 10:11:38 »
Thanks for your reply , I was not sure if Suzuki left enough space for a larger sprocket and chain on front for the spin cycle once again thanks.
Offline highland strom
  • Bike: Suzuki Sv K2 2003.
Re: GEARING
« Reply #3 on: May 06, 2018, 18:56:30 »
17 tooth on my fits fine.
Offline yanky192
  • Bike: DL650 L3
Re: GEARING
« Reply #4 on: May 07, 2018, 09:49:23 »
Hi , Highland Storm  , 17 teeth I could be wrong I looked on that Auction site for new chain sprocket kit and it shows 15 on the front so I have going up 2 teeth would keep the motor smooth I could be wrong maybe standard is 16 teeth .
Offline Mr Nick
Re: GEARING
« Reply #5 on: May 07, 2018, 10:05:29 »
You're trusting the site that lists brake fluid and disk locks as fitting my TS185?  :icon_no:
Orange Bikes Matter!
Online Rusty Nuts
Re: GEARING
« Reply #6 on: May 07, 2018, 12:40:49 »
 :shock: lol
Re: GEARING
« Reply #7 on: May 07, 2018, 13:26:59 »
Hi Yanky. Standard is 15 tooth going up 2 is no problem I do a lot of touring & it definitely suits my riding style. It's drops the revs to just under 4500rpm at 70mph for relaxed touring. Got my sprocket off eBay 17 tooth renthal (part number 289-525-17 renthal).  When I bought my Wee 4yr ago the person who had it before done a lot of touring abroad & went for the 17 tooth option so I didn't know any better. so when it came to changing my chain & sprockets I thought I would try the standard 15 tooth & couldn't get away with it at all it felt far too revvy for my liking so I've went back to the 17 & happy days.
Offline yanky192
  • Bike: DL650 L3
Re: GEARING
« Reply #8 on: May 07, 2018, 20:41:39 »
Thanks for that good advice , I liked the  ts 185 1974 orange and loved it also my dt 250 my first bike Suzuki trail cat 120 at 12 years old ,
