Author Topic: Lower Seat Maybe?  (Read 3662 times)
Offline pegemc
  • Bike: DL650A GT K9
Lower Seat Maybe?
« on: February 26, 2018, 13:54:50 »
Hi All, On my last ride out  it was brought to my attention that my legs were a little more bent than usual whilst riding my wee and that it was possibly due to having different dogbones fitted as they were not the standard silvery metallic colour with a bit of oil and road crud mixed in but in fact a grey colour. When I got back I got out the trusty steel rule and measured the dogbones centre to centre and they measured 140mm which I believe is the standard measurement. Also the preload is set to 4. So does that mean it could be a lower seat and if it is how do I know, does it say on it somewhere. Makes me wonder what the last bloke looked like coz he was over 6' and I'm 5'9"? Any help appreciated thanks. :icon_wink: :thumb:
Pete
Offline Freddyfruitbat
  • Bike: BMW R1200RS
Re: Lower Seat Maybe?
« Reply #1 on: February 26, 2018, 16:49:01 »
Well I have a Glee with the lower seat, but bizarrely that one has no distinguishing markings so I imagine yours will be similar.  The lower seat looks a bit more 'scooped out' where you plant your arse, but I imagine it would be hard to tell unless you've got one of each type in front of you.  You'll be able to find the manufacturer's spec somewhere as to what the respective seat heights are; it's quite hard to measure them accurately in practice, and the difference between the normal and low seats isn't that great; but at least it should give you an inkling.
If the current seat's actually standard, maybe consider a higher one?
Also, if you didn't notice the issue until someone pointed it out... does it matter!?
Offline pegemc
« Reply #2 on: February 26, 2018, 21:42:39 »
Yeah suppose it does make sense really. Both my feet DO feel firmly on the ground and I suppose I wouldn't have noticed if like you say, 'someone pointed it out'. Thought about acquiring one of those air hawk seat pads for long distance comfort and maybe sit me up a bit higher and see if that made a difference, but I'm happy at the moment, see how things go when the weather eventually picks up and I get out on it more regular.
Pete
Offline user650
« Reply #3 on: February 26, 2018, 21:44:29 »
 :whistle: :whistle:
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline pegemc
« Reply #4 on: February 26, 2018, 21:54:05 »
Come on Paul, it was you what set me off! :shock:
Pete
Offline pegemc
« Reply #5 on: February 26, 2018, 22:05:33 »
Got my stickers on by the way!
Pete
Offline user650
« Reply #6 on: February 26, 2018, 22:30:44 »
Them stickers will fix it  :thumb:
Are you sure of the measurements, a little goes a long way.
Stock dogbones are 140mm between hole centers
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline pegemc
« Reply #7 on: February 26, 2018, 22:32:38 »
Yeah measured em and they are definitely 140mm. Must be seat!
Pete
Offline user650
« Reply #8 on: February 26, 2018, 22:39:34 »
The preload was set to 4 as well. If I did that on mine I would struggle to touch the floor :insert short arse icon:
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline pegemc
« Reply #9 on: February 26, 2018, 22:43:12 »
So do you reckon its the seat then?  :shrug:
Pete
Offline user650
« Reply #10 on: February 26, 2018, 22:47:57 »
It might be a standard seat, it looked low that's all, it's why some fit a 1000 seat to lift it about 25mm.
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline pegemc
« Reply #11 on: February 26, 2018, 22:58:19 »
yeah that's what end in tears bloke said, sorry his name escapes me, he bought a DL1000 seat for his wee and after sitting on his it did feel higher. Anyway cheers Paul. :grin:
Pete
Offline user650
« Reply #12 on: February 27, 2018, 00:06:40 »
 :thumb:
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Online Rusty Nuts
« Reply #13 on: February 27, 2018, 08:46:26 »
You mean to tell me Endintears isn't his real name? What about his daughter Tiny, and granddaughter Teeny Tiny?
Offline Loz
  • Bike: DL1000 & Beta300rr
« Reply #14 on: February 27, 2018, 09:19:27 »
Have a look here, its as clear as mud lol
http://www.v-strom.co.uk/smf/index.php?topic=10974.0
« Reply #15 on: February 27, 2018, 12:29:43 »
If you feel that your knees are too, bent try a Cymarc footrest lowering kit as advertised on this site. I have them, very relaxing.
« Reply #16 on: February 27, 2018, 13:26:27 »
Or get someone like Tony Archer to rework your seat. I had 50mm (2" in old money)  added to my seat for extra height. I also had it made wider too with a bit of a step up to the pillion perch too. He has done a few seats for people on here.
Offline pegemc
« Reply #17 on: February 27, 2018, 18:55:08 »
So with the lower footrest does it affect ground clearance much, and what kind of price is it for the seat reworking etc, cheaper than getting a second hand vee seat? Thanks for the seat info by the way Loz :thumb:
Pete
« Reply #18 on: February 27, 2018, 20:19:58 »
I found that lowering my foot pegs put my size 13 toes too close to the floor on adverse cambered corners but that can be countered by raising the rear suspension. The seat mods to my wee cost £80 from Tony Archer but you would need to add carriage charges too. I dropped it off and collected it again so didn't get to find out what the postage charges were.
« Reply #19 on: February 27, 2018, 21:10:10 »
The DL1000 (proper version) has a slightly wider seat than the DL650 (proper version), this was always more comfortable for me  :thumb:
