Author Topic: Clutch microswitch  (Read 1010 times)
Offline sarge1049
  • Bike: Suzuki GSF 650S
Clutch microswitch
« on: February 18, 2018, 08:25:57 »
Team
The clutch microswitch on my 15 plate V Strom appears to be playing up.
Is this a WD40 fix or something more serious?
Thanks
Sarge :ty:
Re: Clutch microswitch
« Reply #1 on: February 18, 2018, 09:27:08 »
Check the meeting of the lever and the switch. If that is proper, your best bet is to replace the switch.  It doesn’t help to list the registration as the bike may have been at a dealer for years. Is it an L4, L5...?
Offline boosabuser
  • Bike: 2014 Strom, CZ125 resto
« Reply #2 on: February 18, 2018, 13:37:58 »
On my AL4 I had the same trouble, my local dealer had one on the shelf and it is a 5 min fix
when I removed the old part there is a orifice underneath the  you can just see the contacts through, it might be worth trying some contact cleaner in there, the switch isn't too expensive if it doesn't work
Offline Dozz
  • Bike: DL650A L3, GSX1400
« Reply #3 on: February 19, 2018, 00:42:45 »
Had similar problem on GSX 1400 made a short wire with 2 terminals on to bypass it before my eBay replacement arrived in a couple of days
« Reply #4 on: February 19, 2018, 02:21:36 »
Short the wires together on a K7 or later DL650 and the bike will tend to die at idle. The ECU uses the switch position as part of the Emissions control loop.
Offline sarge1049
« Reply #5 on: February 20, 2018, 15:14:43 »
Chaps
I added Suzuki hand guards a few months ago, & the clutch lever is wobblier than before. A possible cause?
Sarge
