There are sensors for both wheels but if your only cleaning up the calipers you don't need to touch them. Loosen off the brake pad retaining pins, unbolt the calipers, remove the pins and pads, clean the pistons with whatever, water brake cleaner wd40, pump them out, make sure there all free, copper slip the back of the pad and bob's your uncle.
