Author Topic: New Bridgestone Battlax Adventure A41 tyre  (Read 23233 times)
Offline Froglodyte
Re: New Bridgestone Battlax Adventure A41 tyre
« Reply #60 on: September 23, 2021, 20:36:59 »
I've been using 36/42 on all of my bikes for the last 10 years. My recently sold BMW was unrideable on stock pressures.
Offline Froglodyte
« Reply #61 on: September 23, 2021, 20:44:25 »
It's important to be pumped
Tyre pressures are a crucial factor in determining how your bike handles and how quickly you wear out your (not exactly cheap) tyres.
There are lots of myths and misconceptions about what pressures you should run in the wet, on track days or when you're loaded with luggage. Usually you'll find someone propping up the bar who knows better than the manufacturers' recommendations. To find out how close they are to being right we talked to a genuine expert - a man who should know tyres if anyone does.
Leo Smith spent years as chief development tester at Avon tyres. He is now motorcycle product manager. He said: "We probably get asked more about tyre pressures than about any other aspect of a tyre”. There's so much bad information kicking about that people can't separate the truth from fiction."
Smith says that is largely the fault of tyre companies themselves. Several years ago, different tyre companies recommended different pressures for different tyres and different bikes. But around 10 years ago, a decision was reached between the companies to standardise pressures so that most bikes can run on the same no matter what tyres they're on. That standard is 36psi at the front and 42psi at the rear.
There are some exceptions, like some 400cc grey imports which run 29psi at the front and 36psi at the rear. Another notable exception is the Kawasaki ZX-12R - which is meant to run 42 front and rear. But if you've got a modern, mainstream bike, chances are you should be running the 36/42 standard.
That 42 figure in particular will have a lot of the gentlemen at the bar shaking their heads. But it is not a figure chosen at random. Pressures determine how your tyres deflect. The lower the pressure, the more the tyre will flex. That may make for a comfortable ride when you're cruising in a straight line, but the tyre will flex too fast at speed and make your bike unstable. The bike will feel vague going into turns and feel like it's going to tip into the corner suddenly. This is because the tyre isn't "strong" enough and it's literally buckling under you.
The bike will also feel wallowy through turns and it'll weave under acceleration. Conversely, if you over-inflate a tyre, the flex will be slower but that will make your bike more stable at high speeds. The ride comfort and the tyre's ability to absorb shocks will be lost and your wrists and backside will take the brunt of it. The bike will feel so harsh that many people will think they have a suspension problem.
Cornering won't feel as bad as when pressure is too low, but you will again lose feel and feedback from the tyres. For example, if you ride over a stone, an over-inflated tyre cannot absorb it and the tyre breaks contact with the road. Smith says the classic myth about tyre pressures is that you deflate them for wet-weather riding. He says most grip comes from the tyre's compound and the contact patch - and the shape of the tyre where it contacts the road is everything.
Tread patterns stop water from building up under the tyres - which could cause a bike to aquaplane. Smith says: "A good front tyre chucks enough water out of the way to enable the rear to get the power down. If you reduce the tyre pressure, the tread becomes compressed so it can't clear as much water." If anything, Smith recommends you increase the rear tyre by 2-3psi in the wet but leave the front as it is.
Another widely held misconception is that the psi recommendations are the maximum the tyre can take. They're not. The figure only tells at what pressures the tyres were tested at for all-round use. You could actually safely inflate a type up to around 50psi if you really wanted to, although it wouldn't do you much good.
But the biggest area for debate has to be track days. If you've ever been to one it's almost certain someone has told you you'll be best off reducing your tyre pressures. You get more grip that way, they tell you. Smith has radically different advice.
You should leave them alone, he says. "Racing tyres are of a totally different construction and stiffness to road tyres so they need less pressure to maintain the carcass shape. That's where the rumours and bad advice comes from. "If you drop the psi in road tyres you will get more movement in the tread pattern. They will heat up too much and that will eat into tyre wear. You'll almost certainly ruin a set in a day without gaining any advantage in grip."
Smith says he's known people to drop their rear tyre to just 22psi when heading for the track. His advice is to leave your tyres alone, saying a good tyre at standard pressures will give more grip than you need on a track day because you almost certainly won't be
going as fast or for as long as racers. Track surfaces offer much better grip than the road, too - another reason for leaving your tyre pressures the same for the ride to the track as for the ride around it.
Many people also ask the experts at Avon if they should increase psi to take pillion passengers. Again there's no need. The manufacturers' agreed pressures of 36/42 were arrived at after testing with pillions, luggage, cold tyres and every other combination you could think of.
One of the few cases when Smith does recommend you change your pressures is when your tyres wear. A worn tyre has lost a lot of its strength as the shape and flexibility levels have changed. That means it will handle differently to a new tyre. Try increasing the tyres by 2psi when you're down to around 40 per cent tread depth. It will only make a marginal difference, but it should improve your bike's handling a bit.
You may not have to keep changing your tyre pressures, but you do have to maintain them. Smith recommends that you check them once a week as an absolute minimum but to be extra safe, you should really check them every day because a tyre can change by as much as 3psi on its own just because of changes in the weather.
You should always measure your tyre pressures when they are cold. A few bikes are now coming with tyre pressure gauges in their under-saddle tool kits. If you haven't got one it's worth buying one. They only cost a few quid and take up about as much room as a pen. Forecourt gauges are notoriously inaccurate.
Scanned and re-printed in total from an article in MCN.
« Reply #62 on: September 24, 2021, 07:26:42 »
If I may ask, what is the maximum pressure embossed on the front and rear tyre wall of the Bridgestone A41? I asking, as I am considering these for the K5's next replacement.
When the tyre heats up from riding, how much over the maximum psi tyre rating is allowed. My current rear tyre has a 42 psi embossed on the tyre and I inflate it to 40 psi, so with heat increased pressure, I'm below the max psi rating.
« Reply #63 on: September 24, 2021, 11:34:25 »
Gert, it says 42psi on both my front & rear but I refer you to the reply from Bridgestone I posted yesterday. Plus the post from Froglodyte above gives the same pressures. I can only presume the tyre manufacturers know the pressure will increase during use but that is taken into the equation when they decide on the best pressures (cold)?
"Dear Customer,
                        The 36/42 psi is for both solo and dual riding application. The design and development of the bike/tyre is conducted using one pressure in accordance with the tyre manufacturers regulations.  Lower pressures can be used but of course the lower one goes, the fewer miles will be achieved.  The best advise is to use 36/42 at all times
Regards
Bridgestone Customer Services"
« Reply #64 on: September 24, 2021, 14:48:47 »
I have a set of the A40's sitting in the garage waiting to be fitted to the Varadero.
the last pair lasted well on the fat girl and gave excellent feedback and grip.
Seeing as the A41 are the same compound I can't see them being any different.
I've used various brands over the last 100k miles on ADV bikes and the A40's are a firm favourite.
Anakee 2's were my favourites, but long discontinued now.
Running stock pressures (34F 38-40R) even with the rock hard Heidenau K60s the bike handled like a pig.
upping them 2-3psi made a world of difference and reduced the scalloping on the front markedly.
I tend to run 36F 43R as the bike and myself are a little on the heavy side.
that's with the last set of A40 and the current Tournace (original)
SWMBO's GSX on the other hand likes 36F and 40R - with BT-023 - change that by more than 2 psi on the rear and she's a mess in the corners.
« Reply #65 on: September 24, 2021, 18:57:21 »
Mick, Thanks for your reply. I did take the time to read the earlier post wrt the reply from Bridgestone Customer Services. I just thought was strange that the manufacturer would equal or exceed the tyre embossed PSI warning pressure. I would suggest that you hang on to that reply from the CS. My other concern is, if in a case of either a blow-out / accident / unplanned dismount, would the insurance company not use the tyre over pressure as an excuse to welsh on an insurance claim?
Offline vstroman
« Reply #66 on: September 09, 2022, 23:32:12 »
Another vote for the Anakee Adventure.
I've not ventured much beyond very poorly surfaced back lanes and the odd field but there really confidence inspiring and I think they feel great on road too for an 80/20.
What are the Anakee Adventure like in the wet? don't suppose they'd be as good as Road 5's for example, strongly considering a sport touring tyre but I like the looks of the Anakees and they'd likely be a lot better on gravel tracks etc. also looking at Pirelli Scorpion Rally STR's.
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #67 on: September 10, 2022, 00:26:45 »
I've found them very reassuring in the wet, they are on their last legs at 8.5k though and I suspect this may have been sooner if did many straight line miles.
Can't comment in relation to a more tarmac focused tyre I'm afraid but I'll definitely be booking in for another set early next year.
Offline vstroman
« Reply #68 on: September 10, 2022, 00:59:18 »
8,500 is great mileage considering you are on the 1000cc bike. The 650 would likely do another few thousand.
I won't pull the trigger yet, waiting for the credit card balance to come down a bit!! thanks for the info.
Offline 2112
« Reply #69 on: September 16, 2022, 09:50:46 »
It's an interesting point about tyre pressures. My Tiger's O/E tyre pressure is supposed to be 32 psi front and 39 psi rear, despite the fact the previous model with the same size tyres ran 36 psi front & 42 psi rear. However, at these pressures it feels horrible and won't steer. A quick read on the forums and everyone is running 36 psi front and 42 psi rear. When I fitted the Bridgestone A41's I emailed the UK tyre distributor and they confirmed that 36 psi front with 42 psi rear is their recommended pressure for that model. Odd, but 36/42 it is for me and I'm loving the A41's.
« Reply #70 on: September 16, 2022, 13:03:18 »
I've run the A40's with the same 36 front and 42 rear over a few pairs of them.
Seeing as they have the same carcass and silica/rubber compound as the A41's
« Reply #71 on: September 16, 2022, 20:22:02 »
I did the same when I fitted the A41's last year. Apparently I had been running my previous BT31's at too low a pressure & got premature wear, so wanted to confirm for the A41's.
This is the reply I got  from Bridgestone.............
"Dear Customer,
Regards
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4.
« Reply #72 on: September 16, 2022, 21:12:30 »
I used 36/42 today after reading this thread. It's like riding a different bike, much better.  :text-goodpost:
« Reply #73 on: September 16, 2022, 21:28:16 »
I got the same from Dunlop 36/42 psi. It seems standard across tyre manufacturers
