spotlights?
Topic: spotlights? (Read 2696 times)
argento
Bike: dl650
spotlights?
October 27, 2017, 19:57:35 »
There's lots of cheap spotlights on ebay but are tehy any good? do they need relays too?
http://www.ebay.co.uk/itm/2pcs-125W-Motorcycle-Motorbike-Headlight-LED-Fog-Spot-Lights-Bulb-switch/222423368214?hash=item33c9774216:g:8i0AAOSwCtJZ6biA
Hugh Mungus
Bike: Fazer 1000
Re: spotlights?
October 27, 2017, 20:04:45 »
I don't know how good those lights are but I do recommend fitting via a relay - especially as relays are only about a fiver.
pieman53
Bike: DL1000 K6, DL1000A L9
Re: spotlights?
October 27, 2017, 20:25:12 »
Fitted a set like those over 12 months ago and no problems so far.
user650
Bike: DL650A M3 in fast white (Gen 3), DL650A M2 in fast white (Gen 3)
Re: spotlights?
October 27, 2017, 20:33:32 »
Had mine on for two years,, one failed due to water getting in so put a bit of sealer around the lens and all should be well. Fit a relay best to be safe
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
In me shed
Bike: Gleek 650 XT AL6, BMW R1100RS, KH250 Tripple,
Re: spotlights?
October 27, 2017, 21:22:07 »
They look exactly the same as mine, been on (not literally before you smart arses start)
for 16 months and used every day
argento
Bike: dl650
Re: spotlights?
Reply #5 on:
October 27, 2017, 21:59:17 »
what relay should I use?? are there any cheap omes with relay?
Hugh Mungus
Bike: Fazer 1000
Re: spotlights?
Reply #6 on:
October 27, 2017, 22:40:42 »
Relay
http://www.ebay.co.uk/itm/12V-4-PIN-Car-Relay-30AMP-Normally-Open-Contact-Fused-with-Bracket/191822741692?hash=item2ca986c0bc:g:CVwAAOSwP~tW4A2x
Video
If you need any more information just ask.
user650
Re: spotlights?
Reply #7 on:
October 28, 2017, 00:06:57 »
Fitted to engine bars
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
TLPower
Bike: ThunderBastard (KTM 1190 ADV)
Re: spotlights?
Reply #8 on:
October 28, 2017, 05:59:43 »
A bit of a hijack I know, but if I look at the spikes (intended typo) long enough I can see them starting to rust.
Asmith61
Bike: 2011 B-King 1300 , 2023 Harley Nightster 975
Re: spotlights?
Reply #9 on:
October 28, 2017, 20:26:28 »
I have had the same spotlights as these for a couple of years now, and have been OK so far,I have also fitted my to my heed bars hopefully I still have the pictures, I fitted a switch to mine.
argento
Bike: dl650
Re: spotlights?
Reply #10 on:
October 29, 2017, 18:17:37 »
without relay?
Where did you connect the wires is ther an easy ignition switch connection?
Asmith61
Re: spotlights?
Reply #11 on:
October 29, 2017, 19:18:46 »
Hi I have one of big pies aux boards avalible from him from the forum so it was easy to wire them up and yes through a relay
spotlights?
