I had a pair of those on my bike
I know this subject for some must be
ZZZZZZ,
but did you fit a relay, as it says the following.
"These lights are small and compact but throw out a lot of light and due to the low wattage.
It can be used on any vehicle without having to upgrade your electrical system.
They can be wired directly into your headlight dipped beam, or can be used on a separate switch".
I want them on all the time so I'd want them wired to the dipped beam, so won't be using another switch. If a relay is needed, what one should I buy. I really don't fancy frying my electrics. And I take it that the red wire goes to the live wire on the dipped beam, and the black to earth somewhere.
Again sorry for the repetitive question
