Idle speed - DL1000 2005
Topic: Idle speed - DL1000 2005 (Read 1253 times)
markyp33
Bike: Honda Blackbird 2002, DL1000 K5, Honda CX500
September 25, 2017, 11:10:30 »
Hi
Could anyone tell me the idle speed for this bike - it seems to be a bit high to me at around 1200rpm
Thanks again
Mark
SuzukiSte
Re: Idle speed - DL1000 2005
September 25, 2017, 11:56:24 »
1200-1300rpm don't forget it's a V-Twin needs the rev's for pulling away from standstill hope this helps
Paz324
Bike: CB1000RAJ
September 25, 2017, 12:50:59 »
Around 1200rpm is standard for a lot of bikes now.
greywolf
September 25, 2017, 14:48:01 »
Suzuki says 1200rpm +/- 100. There should be a spot in that range that neither stalls nor hangs high before coming down. The 650's spec is 1300rpm +/- 100 so don't feel like it's too fast.
markyp33
September 25, 2017, 15:16:27 »
I think its because I've just come from a 4 cylinder bike. Thanks for all your replies - it has put my mind at rest
greywolf
Reply #5 on:
September 25, 2017, 16:38:32 »
That would be why. There are more pistons and more firing cycles involved in each revolution. It takes more revs to keep up an idle with one or two cylinders unless the flywheel mass is greater.
