Author Topic: 2007 DL650 FI light  (Read 2371 times)
Offline bob dumbell
  • Bob D
  • Bike: DL1000 L5 Desert
2007 DL650 FI light
« on: September 12, 2017, 16:36:32 »
Hi blokes been on the forum with this problem a few months ago, problem still there intermittent, but happening more often, just completed the nc500, and light on most of trip, bike runs fine, found the white socket under the battery ppositive terminal, took black cap off, only 2 wires on it diagonally opposite, put link across them but no code came on in the instrument panel any ideas, have I got the correct socket? I'VE attached socket photo
Re: 2007 DL650 FI light
« Reply #1 on: September 12, 2017, 16:41:05 »
If you have a non ABS bike, the dealer mode coupler is under the seat inside the left cover. Look for a white/red wire and a black/white wire. Those are the ones that need to be connected.
Offline bob dumbell
  • Bob D
« Reply #2 on: September 12, 2017, 17:17:20 »
Had a more indepth look and checked out DR VStrom on you tube, found the socket, mines an ABS bike, sockets on the right hand side at the back of the tank shorted it out and got the C40 code, that's a start point, Dr VStrom gives a number of possible faults one being ISC valve circuit open or short circuited to ground, time to speak to my leckie mate!
« Reply #3 on: September 12, 2017, 18:16:22 »
Here's the connector for the 2007 ABS model from http://www.vstrom.info/Smf/index.php/topic,7061.0.html
Make sure the vacuum hose is connected and not kinked or otherwise obstructed. It could be the ISC valve preset needs to be reset.
1) Turn the ignition switch to the OFF position.
2) Remove the seat.
3) Put the bike in dealer mode.
4) Turn the ignition switch to the ON position.
5) Turn the ignition switch to the OFF position.
6) Then, wait more than 5 seconds.
The ISC valve automatically is set at the PRE-SET position.
7) Take the bike out of dealer mode.
Offline bob dumbell
  • Bob D
« Reply #4 on: September 13, 2017, 09:11:25 »
Brilliant thanks for the info I'll give it a try
Offline bob dumbell
  • Bob D
« Reply #5 on: September 24, 2017, 00:38:10 »
Hi blokes and thanks grey wolf, bike reset , but then came on again with the same after a few miles. I'll have to try a get to the valve and get it checked out. Tried to  find a new Isc valve but having problems sourcing one in the uk, any thoughts?
« Reply #6 on: September 24, 2017, 01:26:50 »
Double check the wiring and connections. Also make sure the vacuum hose is in place and in good condition. Such a problem is usually with the hose or wiring as the valve itself is rarely the problem.
Offline bobbymc
  • Bike: DL650 K9
« Reply #7 on: September 24, 2017, 19:32:18 »
I'd like to post a new post about my DL650 not starting today, But I'm blowed if I can work it out !
The bike was warm and when I tried to start it, it would turn over but not start.
There was a red flashing light on the central dash.
I pressed a few buttons and turned the bike on and off at the ignition switch, checked the fuel level....and it started at the next press of the starter button.
Are there any connections to check for connectivity ?.....Bob Mc
I have a 2009 DL650.
« Reply #8 on: September 24, 2017, 20:47:44 »
Bobbymc, please start a new thread on your problem and include the model year of your bike. Lets do one problem per thread.
« Reply #9 on: September 25, 2017, 13:17:32 »
Bobbymc
You are looking for the button shown by the red arrow. PM me if you have difficulties.
