Author Topic: C17 FI CODE  (Read 3799 times)
Offline mx_ritchie13
  • Service Not Self
  • Bike: 2011 Suzuki V-Strom DL650, 1989 Honda C90
C17 FI CODE
« on: August 13, 2017, 16:33:48 »
Good afternoon blokes,
                                     Has anyone any ideas please? I had the C17 code come up on my 2009 Wee which is the Intake Air Pressure Sensor so I changed each one in turn but I am still getting the fault. I had a friend take a look with his meter and he also checked for a blockage but couldn't find anything. If anyone can help that would be great?
Cheers blokes
Ritchie
Re: C17 FI CODE
« Reply #1 on: August 13, 2017, 16:45:56 »
  • Service Not Self
Re: C17 FI CODE
« Reply #2 on: August 13, 2017, 16:55:16 »
Thanks for the reply. I'm pretty certain they are fully seated but will check again ????
Re: C17 FI CODE
« Reply #3 on: August 13, 2017, 18:50:47 »
If the wiring all checks out and there is no vacuum hose leak or blockage, the sensor itself is the only suspect left.
  • Service Not Self
Re: C17 FI CODE
« Reply #4 on: August 14, 2017, 15:36:32 »
Cheers blokes,
                 I've put two new sensors on and checked they are in fully. Only thing for it is to put it in the shop to check the rest.  :GRR:
Thanks again  :)
Ritchie
Re: C17 FI CODE
« Reply #5 on: August 14, 2017, 15:57:03 »
