December 12, 2024, 21:34:00
Author Topic: Optimiser which one.  (Read 4365 times)
Offline pawl
Re: Optimiser which one.
« Reply #20 on: August 15, 2017, 21:34:45 »
Thanks for the great advice . Oxford optimiser on its way .
Online Rusty Nuts
« Reply #21 on: August 15, 2017, 21:57:51 »
Did you know the bike in your avatar is reversed?
Offline philthunder
  • Bike: Strom 1000 2017
« Reply #22 on: August 16, 2017, 08:58:18 »
Freddyfruitbat. That looks like it can be left on all the time, it is microprocessor controlled so it should only put a charge in, when it is needed. If you have a voltmeter you can check the part charge and the full charge voltages. Should not go above 13.5 volts
What is this life if full of care we have no time to stand and stare, and rev the nuts off the beast.
Offline Robotstar5
« Reply #23 on: August 19, 2017, 21:59:28 »
I've been using Optimates for probably 20 years, some bikes have had one connected for up to 6 months without any problems, haven't had a battery fail yet, but did have an Optimate fail after 15 years  :)
