Author Topic: pad replacement  (Read 1680 times)
Offline tony d
  • Bike: DL1000 L5
pad replacement
« on: August 05, 2017, 18:00:30 »
after replacing      both back and front pads on my vstrom 1000 the abs and tc lights want go out   any ideas
Offline user650
Re: pad replacement
« Reply #1 on: August 05, 2017, 18:46:06 »
Have a look at the front and rear abs sensor as you may have caught it when doing the pads, what mileage have you got?
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #2 on: August 05, 2017, 19:27:10 »
15000 it only happened after replacing pads
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #3 on: August 05, 2017, 19:30:39 »
also got new rear tyre the fitter said the ecu might need reseting
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #4 on: August 05, 2017, 19:37:59 »
 I cleaned the abs ring on rear wheel if that makes any difference
Re: pad replacement
« Reply #5 on: August 05, 2017, 19:38:39 »
The ECU is not a learning type. Check the sensor placement, wiring and sensor rings.
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #6 on: August 05, 2017, 19:41:13 »
OK thanks are the sensors prone to this type of fault
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #7 on: August 05, 2017, 19:46:09 »
is the sensor a tiny little magnet because I found one on the floor cylinder type
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #8 on: August 05, 2017, 20:11:15 »
update removed the rear sensor its snapped in half  a bit clumsy removing caliper thanks again for the help
Re: pad replacement
« Reply #9 on: August 05, 2017, 20:45:26 »
Always remove the sensor first and replace it last when working on a wheel. Do not take a chance by leaving the sensor in place. It is fragile and expensive. The sensor is a magnet plus coil. The alternating steel then blank rectangles in the ring cause a pulse change in magnetic field as the field is stronger with the added steel and weaker at a blank hole. The field pulse translates to a power pulse in the sensor wires.
Offline Hugh Mungus
  • Bike: Fazer 1000
Re: pad replacement
« Reply #10 on: August 05, 2017, 20:53:34 »
That sounds like someone saying "Bugger" a few times...
Offline tony d
  • Bike: DL1000 L5
Re: pad replacement
« Reply #11 on: August 05, 2017, 21:17:11 »
thanks again will bear that in mind especially after removing the tank and  wheels again looking for a split wire and many expletives
