Author Topic: Plugs 8 or 9  (Read 1279 times)
Offline M yates
  • Bike: 2008 vstrom 1000 GT, zx10(88) , piaggio x9 500
Plugs 8 or 9
« on: July 30, 2017, 14:56:27 »
 :fix: hi big trip coming up giving bike once over, checking the plugs seem OK standard cr8,rummaging around found a set of cr9eix (x4 new) ooh me thinks save money, now I know these are a colder plug but surely still stays within the heat range. All advice and quips welcome, also having to replace sprocket carrier bearing (cage coming apart bike on 30k) seems to be a thing anyway thanks in advance  :ty:
Offline Sasquatch
  • Bike: DL650GT K9
Re: Plugs 8 or 9
« Reply #1 on: August 03, 2017, 21:14:23 »
my sprocket carrier bearing died long before 30k, at 29k it had massive play and cage in 3 pieces. You'll need hydraulic press to get one out, even after heating up needed 4 tonnes of persuasion to get bastard out. New one frozen in freezer, housing heated in owen to 250 Celsius and bearing fell in.
Can't help with spark plugs  :shrug:
Re: Plugs 8 or 9
« Reply #2 on: August 03, 2017, 21:27:02 »
I would stick to the stock heat range. A liquid cooled bike maintains combustion chamber temperatures very well and a plug outside that heat range will need to be replaced earlier, negating the savings.
Offline M yates
Re: Plugs 8 or 9
« Reply #3 on: August 04, 2017, 14:59:38 »
Thanks for your advice stock plugs it is, will try big hammer first if not of down the stealers they can do it ! . :ty:
Offline M yates
Re: Plugs 8 or 9
« Reply #4 on: August 05, 2017, 13:23:45 »
That's OFF down the stealers. :groan:
