Sorry kwackboy, got to completely disagree with you about setting them slack and not checking them again, unless I misunderstood what you meant. (This is entirely possible!)
Valve clearances have upper and lower limits. On, or between these limits means take no action. The valve clearances are good and require no further attention until the next scheduled service. Nothing bad is going to happen, and by altering them nothing will improve. Your engine will not run better, it will not give more mpg or power, it will not last longer, and yes, you absolutely must check them again at the next recommended interval.
If any are out of spec, replace the shims to put the spec IN THE MIDDLE of the upper and lower limit. This is the optimum valve clearance setting. This allows some movement of the clearances either up or down, and means WHATEVER IS HAPPENING IN YOUR ENGINE will be picked up and corrected at the next check WITH NO DETRIMENT TO YOUR ENGINE OR ITS PERFORMANCE. Valve clearances on most modern engines TEND to tighten not loosen. Yours may not though. If you have set them to maximum in spec clearance, and they loosen a touch, you now have an engine running out of spec. Set them in the middle and you have leeway either way, whatever happens.
It can take 20,000 - 100,000 miles for your engine and all its components to fully bed in. Until this time each intervention can unsettle it, and result in different tendencies. Eg, first valve check, 15,000 miles, everything in spec. Good, as it should be. Do not attempt to fix something that is not broken at this stage.
But we noticed one exhaust valve at maximum. Hmmmm. Record these results. DO NOT feck ABOUT WITH IT, IT IS FINE.
2nd check, 15,000 miles later
1 inlet valve out of spec, but that exhaust valve that was on maximum, is still on maximum.
Change the inlet shim, aim for middle of spec. Do not be tempted to remove a cam where all the clearances are still in spec. Leave it the feck alone if it measures good. If exhaust and inlet are operated by the same cam, and it is coming out anyway, then OK, if you must, change that exhaust shim to bring it to middle spec. Hell, do them all, lets get it perfect. Needed? NO. Sensible? Not really. Would I? No. What the hell, in there anyway, lets get it perfect is understandable, but pointless. Did you balance the camshaft while it was out? Did you remove and polish the valves, and check/lap the valve seats? Remove, polish and balance the pistons and con rods? Check piston size, bore size and machine to fit? Balance the crank? Why ever not? Doing any one of these individually makes no difference. Do all of them, along with the squish clearance on each piston/head and you now have a blue printed engine. Splendid. But on a low stress, low performance DL engine? Utterly, utterly pointless. But it will be deliciously, noticeably smoother.
On a high spec, high rpm, high power motor for racing, yes please. For anything else you risk disturbing a sound motor by introducing change, which can have unexpected consequences.
Do not attempt to fix that which is not broken. Wise words that our op may wish he'd heard earlier....
To the op, if it were my engine I'd trust my own measurements and only act on an out of spec measurement, ignore everything else and in the absense of any worrying symptoms, check again at the next scheduled check, while listening out for worrying symptoms. These are not hi-spec, fragile, tempermental engines, the very opposite in fact. Chill.
