Author Topic: O/D  (Read 808 times)
Offline bigsimmo
  • Bike: DL1000 K8 in blue / glee in red
O/D
« on: July 23, 2017, 17:06:47 »
hi blokes, any one know why my "O/D" lcd, on the dash comes on in fifth as well as sixth, it also stays on when going from sixth in to fifth. vee k7.
thanks blokes...
steve
Re: O/D
« Reply #1 on: July 23, 2017, 18:09:04 »
It's triggered due to resistance level in the circuit from the resistor pack in the gear position switch. Added resistance in the wire connections from corrosion, oxidation, etc. can cause what you are seeing.
Offline bigsimmo
Re: O/D
« Reply #2 on: July 25, 2017, 15:58:56 »
thank you sir, she is in today so I will add that to the list for them to look at.
I like to know a bit about about the problems first.
steve
