Author Topic: Sat Nav mounting  (Read 5505 times)
Offline Northants trooper
  • Bike: 2011 dl650 vstrom
Sat Nav mounting
« on: June 18, 2017, 09:25:51 »
Hello all,
I've seen on a few stroms a bar at the bottom of the wind shield where people have there sat navs. Any idea where I can find one and any recommendations for a good but affordable satnav
Not all those who wonder are lost, but I probably am
Offline King Orry
  • Bike: Glee
Offline Rich:-)
Re: Sat Nav mounting
« Reply #2 on: June 18, 2017, 11:31:03 »
Easy - make one.
I used a couple of bits of stiff alloy sheet and a section of old steel handle bar, lick of black paint - job done.
Others have made similar out of copper or even plastic plumbing bits.
There are these things though if you want to be posh.  :grin:
http://ravetechmotorcycles.com/store/en/Suzuki-DL650-v-strom/23-DL650-accessory-bar.html
I just googled "vstrom gps bar" btw.
Offline John G
  • Bike: 2016 Suzuki DL1000 AL6
« Reply #3 on: June 19, 2017, 09:51:08 »
Zumo 350lm is a great GPS for motorcycle. I've had mine for 5 years without problems and free map updates. Remember that motorcycles expose GPS to harsher conditions like vibration and rain so the more robust design may be cost effective.
The Zumo range is expensive but 350lm are discontinued so you may be able to get hold of one that a retailer is holding in stock.
I posted on May31st a home made mounting system for Sat Nav but it is for the later models with single unit headlight.
Offline Mark.Nash
  • Bike: DL650
« Reply #4 on: June 19, 2017, 18:49:09 »
I used this one from Ravetech.
Arrived promptly, and was a perfect fit.
http://ravetechmotorcycles.com/store/en/Suzuki-DL650-v-strom/1-dl650mgps.html
Offline Theflyingscot
  • Bike: DL1000 K7
« Reply #5 on: June 20, 2017, 21:27:53 »
Made my own, cost me £4!
Water is wet, Sky is blue. If you are after answers to any other questions Google it!!!!!
Offline Loz
  • Bike: DL1000 & Beta300rr
« Reply #6 on: June 23, 2017, 09:05:37 »
Purchased a cheap ram mount from fleabay - item no 302288415183 which arrived from Hong Kong within 8 days  :thumb:
I do not plan to mirror stem mount it, but will attempt to make up a behind the screen bar and attach the ram mount to it  :fix:
Offline Ravetech
  • Bike: 2015 DL1000
« Reply #7 on: June 25, 2017, 02:46:54 »
We do two dash mounts for the 2012-2017 DL650 RAM mount only or bar with RAM mount. We also have mounts for the new model on the way.
www.ravetechmotorcycles.com
« Reply #8 on: June 25, 2017, 02:53:53 »
2017 is the new model, different from the 2012-2016.
Offline mrp192
  • Bike: V-Strom 1050
« Reply #9 on: June 25, 2017, 10:08:43 »
I have a Zumo 340, one of the discounted ones Aldi were selling last year, and just use the mount that came in the box in the middle of the handlebars.
This puts the unit just below my field of vision which I prefer for an occasional check. I realise some may say this takes your eyes off the road but I think this is preferable to riding to the road on the satnav rather than what I can see ahead with my eyes.
This was brought home to me when working with a highly trained driver on a cross country route and their driving was crap. As an experiment I covered the satnav in the car and immediately their driving improved to what I would have expected from them.
Horses for courses but this is my experience and hope it helps the discussion here?
Offline Sasquatch
  • Bike: DL650GT K9
« Reply #10 on: June 25, 2017, 16:38:06 »
I've found Sat Nav on handlebars too low, checking next turn distance was taking too much time. Having it just above the speedo is perfect, can peek at it without losing road from field of view.
Offline Loz
« Reply #11 on: June 25, 2017, 18:35:32 »
I have a stem mount ball fitted, which is great, until you use a tank bag..
Offline vstroman
« Reply #12 on: October 19, 2017, 08:16:22 »
That's a good point, I'm looking at getting my first Sat Nav and trying to decide which is the best mount to use,I already have a 12 volt socket on the handlebars for powering it, looking at the Zumo 345 lm.
Offline mrp192
« Reply #13 on: October 19, 2017, 08:46:49 »
I like my 340. You can bend a route from TYRE onto it if you put the waypoints in the right places you just have to go through a bit of faff when you first load the route changing the preferred option to off road then back to normal to get it to comply. I think the 345 has the twisty road option but not sure.
I have just seen the 345lm online for under £300 as looking for a mate who wants one. I also like the smaller 4.3” screen as the Glee dash area is quite compact.
Offline vstroman
« Reply #14 on: October 19, 2017, 10:05:59 »
Thanks, the only thing I don't like is 345lm has only got western European maps,
the 395lm has full Europe maps.
Offline mrp192
« Reply #15 on: October 19, 2017, 14:26:18 »
That’s fair enough but wasn’t an issue for me as I doubt I will ever venture abroad anyway. I see the 395 is the same size as the 340/345 which is what mattered to me as it’s a little bit of a faff to reach the ignition key anyway, a bigger unit would probably mean taking the satnav off the mount to use the key.
Offline Lincsman
« Reply #16 on: October 19, 2017, 17:34:28 »
Yes the 345 has twisty routes, something I'll try when the rain stops. Well you live in hope don't you.
DO YOU CARE ??
https://www.mag-uk.org/
« Reply #17 on: October 19, 2017, 18:05:31 »
Garmin curvy roads took me through a big council estate because it had more twists than the straighter road that went past it.  It's not all that it could be.
Offline Gary lad
  • Bike: SUZUKI DL 650 AK7 GT
« Reply #18 on: October 19, 2017, 19:07:51 »
Hi
I have this set up on mine just a piece of overflow pipe with two bolts either side which attach through the spare holes from the screen and a satnav case hope this helps photos attached
