It's yellow because I didn't like orange. Adding electronic cruise control, a voltmeter, an air horn, heated gear that has separate controls for body and hands turns plus off when the brake light is held on, a garage door opener, GPS with MP3 player feeding head phones, headlight relays, speedometer correction and a fuse block switched on and off with the ignition while carrying an air compressor and a socket set adds a lot of stuff under the seat. Not properly planning the wiring ahead of time adds to the amount of stuff, similar to the previous sentence.
I see you tried a word that Americans use instead of a bit cold or somewhat brilliant and the Americanism filter chose the wrong option. That's always a source of fun.
