Author Topic: 7500 mile service and plug change.  (Read 2797 times)
Offline Captain
« on: April 24, 2017, 14:19:23 »
Hiya all my 2016 Veek has just had its 7500 mile service. Cost was £392.
Now I found on here a revised service schedule which had the spark plugs checked at 7500 and replaced 15000. At the bike show live last year I spoke to the lads at ngk and they said a minimum service life of 20000 but usually you get 30/ 50 thousand out of a set of plugs. I've spoken to Suzuki uk and they say they should be changed at 7500. Is this the general consensus also what are they saying across Europe as to when they should be changed?
Cheers fellow strommers.
Offline bosnjo
  • Bike: DL1000 L7
Re: 7500 mile service and plug change.
« Reply #1 on: April 24, 2017, 14:44:02 »
Mine is almost at 30.000 km's now and still on original plugs. I have no intention of changing them soon.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
« Reply #2 on: April 24, 2017, 15:06:12 »
Iridium plugs are good for 50,000 miles. Even the old non-Iridium plugs were good for 20,000 miles. Suzuki's plug change interval is bollocks.
Is that the proper UK expression for stupidly wrong?
Offline StromGeeza
  • Global Moderator
  • Bike: just scoots now
« Reply #3 on: April 24, 2017, 15:56:00 »
Indeed it is.  :)
Offline arran66
  • Bike: DL1000 2015
« Reply #4 on: April 24, 2017, 16:33:32 »
I change mine at 15000 miles
so the plugs last at least to 15000 they looked OK too
but as I was having the valves checked anyway
so I just changed them at the same time
Online Rusty Nuts
« Reply #5 on: April 24, 2017, 17:30:22 »
If they insist on changing them, insist on having them back and keep them for spares.
« Reply #6 on: April 24, 2017, 17:37:06 »
Almost 400 quid for the minor service what a rip off!
I've 13k on mine, never done nothing apart from oil from the 500 miler.  Arran66 did any of your bikes valves need adjusted at 15k ? I'm hoping to ride mine till 30k without doing a thing.
Offline arran66
  • Bike: DL1000 2015
« Reply #7 on: April 25, 2017, 16:47:39 »
porter
no adjustment was needed this time round
but I do advise you too get them checked
you can cause damage too the shims if there out
costly if you do... to change shims its cams out = £££££
I go really steady on mine I don't rev the nuts out of it
so depends on your riding style weather adjustment is necessary
also my air filter was really dirty this time round at 15000 miles
I changed this myself at 8000 miles.... so new filter too
 :thumb:
« Reply #8 on: April 25, 2017, 17:44:01 »
Thanks. I've never done the air filter, I'll do it at 15k.
My last 3 bikes have not needed any shims at the first major service ( two triumphs and a yam fz1) so was hoping to save the money. My dealer wants 500 quid for the service! Outa warranty here so I'll use someone else r check myself.
I don't rev it much either, I'm two up all the time so hopefully she'll be OK. Thanks.
Ps it does get oil every 3k and oil filter every other change.
Offline arran66
  • Bike: DL1000 2015
« Reply #9 on: April 25, 2017, 21:34:09 »
I do all the basic servicing
but valve clearance and throttle bodies balanced I went too Suzuki for a quote £280 just too do throttle and valves...while I was there bought new plugs £74 from the dealer ... so I said ill think about the service contacted steve lynham swindon same service as quoted from Suzuki steves shop £100 and while the top ends off he will put my new plugs in too... that quote is just the valve clearance and throttle bodies balanced ill change oil and filter myself its amazing hes £180 cheaper than the dealer so lets see oil semi synth and k&n filter £39 ebay... plugs £74 Suzuki... valve clearance and throttle bodies balanced £100... grand total £213 for the 15000 mile service and a stamp in the service book.... where do Suzuki get there prices from???
Offline zippy
« Reply #10 on: April 25, 2017, 21:42:32 »
blokes , do they need special tooling to set up the bodies ?? ie switch of certain items ( idle control valves etc) then set them
Offline Leighmorgan
  • Live life to the full
  • Bike: DL1000, V-Strom 2016 and Husqvarna te450 2010
« Reply #11 on: April 28, 2017, 07:39:48 »
Had my 7500 mile service last week but bike only done 4000 they didn't change the plugs the time Suzuki say it takes for 7500 service is 4hrs mine was done in 1 1/2 hrs so I think I'm going to start servicing bikes £400 for 1 1/2 work not bad at all lol ????
Offline stevecro
« Reply #12 on: April 28, 2017, 10:12:01 »
I think they set the stopwatch from the time you turn the key off. 100 pounds per hour while it cools down - bargain!
Offline ziggy
« Reply #13 on: April 28, 2017, 16:32:57 »
Mine at the 15000 mile service found all 4 exhaust valves tight.
