Author Topic: rear wheel hitting mudguard  (Read 859 times)
Offline colin
« on: April 14, 2017, 12:37:58 »
Since fitting rear suspension lowering links the rear wheel makes contact with the underside of the rear mudguard when riding 2 up with full luggage. noticeable when going into a dip in the road compressing the suspension. I have wound up preload to maximum and altered the damping one turn clockwise.  just wondered if a hyperpro spring would help or is it possible to fit another bump stop to the piston rod of the shocker to limit travel.  anybody had one apart?
Offline chris1200
  • Bike: 2008 V Strom 650.
Re: rear wheel hitting mudguard
« Reply #1 on: April 14, 2017, 14:02:05 »
Well the Hyperpro spring works when the bike hasn't been lowered if that's any help. I had the same problem and fitted one to the original shock. No problem at all now two up with full luggage. As to will it do the same with a lowered bike I don't know, but I have no doubt someone on here will tell you!
Offline SuzukiSte
« Reply #2 on: April 14, 2017, 15:31:37 »
Make sure the wheel does not eat away at the underside, and make a hole a big problem if it does, as water will get in under the seat. :thumb:
