Diagnostic Connector DL1000 04
Topic: Diagnostic Connector DL1000 04 (Read 1717 times)
Tagmanone
Bike: DL1000 K2 (on 04 plate) Blue
April 10, 2017, 19:29:09 »
Can anyone tell me if the 2004 DL1000 has a diagnostic connector, if so where. Keep looking but no can find? Would like to fit a gear change indicator but it requires this connector.
Thanks.
Eric
No matter how many corners you get always stay on the straight and narrow.
greywolf
Re: Diagnostic Connector DL1000 04
April 10, 2017, 20:30:18 »
It does. It will be in the area of the left side cover under the seat. I believe six hole connector began with the K4.
Tagmanone
April 11, 2017, 19:34:09 »
Thanks Greywolf. Will take a look.
Eric
Tagmanone
April 14, 2017, 07:34:01 »
Had to return item as had 6 pin connector and only found a 4 pin and an 8 pin connector right where you said. Many thanks for you input.
Eric
greywolf
April 14, 2017, 15:35:18 »
Are you sure you have a K4? K2 and K3 Vees have a four pin connector.
http://www.vstrom.info/Smf/index.php/topic,7061.msg82938.html#msg82938
K2 and K3 Vees have a fixed windscreen that mounts with two screws and a tab. Later models have a changeable windscreen mounting position using four screws.
