Removing the main stand - What's involved?
Topic: Removing the main stand - What's involved? (Read 1413 times)
Descolada
March 26, 2017, 16:45:40 »
Hi Folks.
Just wondering if any of you have experience removing the main stand, what's involved and how much of a PITA to complete? Mine needs some serious TLC.
DL650 AK9
Thanks
Des
greywolf
Re: Removing the main stand - What's involved?
March 26, 2017, 17:05:21 »
It's two bolts on each side and two springs. It's a good idea to use a puller to remove the springs first so the bolts don't get bound up or damage the tapped holes.
Holmsey
Bike: DL650 L9
March 26, 2017, 20:40:26 »
Get rid of the crud that's built up so you can see the bolts ..... If it's anything like mine
Life on two wheels is better than 4 because the wife don't go on two wheels " I'M FREEEEEEEEEEEEEEEE "
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
FlyingPanMan
Bike: KLV1000 2004
April 01, 2017, 10:56:49 »
An old trick for removing tight springs is to insert a coin (2p?) between each coil in the spring. This has the effect of lengthening the spring and is usually sufficient to release it. Leave the coins in for replacement.
Descolada
April 01, 2017, 21:06:56 »
Unnecessary quote removed
That's a nice tip thanks.
