Author Topic: Glee Indicator lenses  (Read 1054 times)
« on: March 23, 2017, 22:31:34 »
I have a supplier telling me that the lenses on a Glee are handed (L+R) and they are different front and back, is that right?
Re: Glee Indicator lenses
« Reply #1 on: March 23, 2017, 23:38:41 »
There are two part numbers for four places. The same part numbers are neither for one end nor one side. It makes me wonder if the fiche is correct. The positions are listed for the complete signal with the lenses alone listed below each complete signal listing.
Front right hand - 35612-08J01
Front left hand - 35632-08J01
Rear right hand - 35632-08J01
Rear left hand - 35612-08J01
« Reply #2 on: March 24, 2017, 07:14:57 »
Yes they are handed as I purchased a set of orange flasher lens recently to replace the clear ones.For example:NSF is the same as OSR and vice versa for the other two.
« Reply #3 on: March 24, 2017, 12:34:31 »
Thanks folks, of course it makes sense for them to be handed but I couldn't see any logic in them being four separate (different) parts.
« Reply #4 on: March 24, 2017, 12:56:34 »
Now I get it. The difference is each lens has a water weep channel at the bottom. Switching sides or switching ends would move the channel from the bottom to the top. Therefore, the two like parts would be at opposite corners. Moving a lens to the opposite side and opposite end would put the weep channel back on the bottom.
