I have had the traction control setting on 2 over the winter, but yesterday decided to change it to 1. At first the select switch was a bit stiff, but it moved after a bit of jiggling and I changed the setting. I then noticed that my heated grips, which are a Suzuki fitting, had come on, and wouldn't turn off unless I switched the ignition off. Subsequent test showed that they will come on every time I use the mode or select switches and again I have to switch off the ignition before they will go off. Anybody else experienced this or have an idea for the reason ? Thanks in advance
