FRONT END KNOCKING NOISE
Topic: FRONT END KNOCKING NOISE (Read 3844 times)
Gary lad
Bike: SUZUKI DL 650 AK7 GT
March 14, 2017, 16:24:11 »
HELLO
MY 2007 DL HAS A LOUD KNOCKING NOISE ON THE FRONT END WHEN GOING OVER ANY ROAD GRIDS OR BUMPS ANY HELP OR IDEAS PLEASE
Holmsey
Bike: DL650 L9
Re: FRONT END KNOCKING NOISE
March 14, 2017, 16:29:04 »
I had that when my head bearings were going .... stopped when I had them changed. .
Raise the front wheel and move it from side to side ... It may feel notchy .... Whilst the front wheel is lifted stand in front of the bike and pull the forks towards you ... If you feel movement the bearings may be gone. .
Life on two wheels is better than 4 because the wife don't go on two wheels " I'M FREEEEEEEEEEEEEEEE "
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Holmsey
Bike: DL650 L9
March 14, 2017, 16:29:36 »
*Notchy*
IBA Member
Gary lad
March 14, 2017, 17:15:44 »
Thanks holmsey will try it
Moo
March 14, 2017, 19:00:20 »
I thought this was a well known problem...
I get the knock when going over bumps, even after the bearings were renewed and tightened
Brockett
Bike: 2022 Moto Guzzi 850 V7 special in blue, 2022 850 V7 Stone in darkest black, 1998 XJ600n in red. 2021 Royal Enfield 500 Classic stealth.
Reply #5 on:
March 14, 2017, 19:07:28 »
Sometimes the "clonk" is wear to the tank front mounting / bolt.
chris1200
Bike: 2008 V Strom 650.
Reply #6 on:
March 14, 2017, 19:33:00 »
Yeah, I get it as well occasionally. Pretty sure it is the tank bolt. There is a fix on the site somewhere I think if it annoys you too much.
Gary lad
Reply #7 on:
March 14, 2017, 19:42:27 »
thanks for the info I will try and find it on the forum brokett
Brockett
Reply #8 on:
March 14, 2017, 19:58:23 »
Check your headrace bearings just the same
Gary lad
Reply #9 on:
March 14, 2017, 22:01:05 »
Sorry brokett but what are headrace bearings not very mechanically minded
Brockett
Reply #10 on:
March 14, 2017, 22:34:08 »
The bearings as described by Holmsey.
I call em headrace because I am old fashioned.
Ideally put the bike on the centre stand and get someone to push the back wheel down and hold the bike still. You stand or squat in front of the bike, grasp the lower fork legs and check for rocking movement in the steering stem bearings by pulling and pushing the fork legs. If any movement is felt then it is most likely to be the bearings. Although they can be tightened I have always found the bearing surfaces have become pitted by the time any noticeable movement is evident. New bearings is the answer.
Gary lad
Reply #11 on:
March 15, 2017, 08:22:08 »
Are got it going to have a look today
Thanks Brokett
PZ
Bike: DL650XT L6
Reply #12 on:
March 19, 2017, 16:16:19 »
I get the same on my 2016 Glee, I thought it was normal and never gave it much thought...
Angustoyou
Bike: 2013 Glee
Reply #13 on:
March 19, 2017, 22:25:50 »
No, knocking isn't normal. Even new bikes can have badly adjusted head bearings. They're not sealed units like wheel bearings. Loose ones will wear quickly causing notchiness. Easy to check, as advised above.
Gary lad
Reply #14 on:
April 23, 2017, 18:00:59 »
Just a update for you blokes
I am having issues with the bike cutting out but that's another problem so while had the fairings off removed the tank and put insulation tape on the tank bolt not too much and greased it up replaced so far no banging and clunking at the front again happy days
