Author Topic: Heed crash bars and skid plate  (Read 1267 times)
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« on: March 10, 2017, 06:52:45 »
Thinking about getting these for the Glee, but I'm not the most mechanically minded so just wanted opinions on how easy they are to fit. It looks to be just a few bolts.
To give you an idea of my competency,  I fitted a Givi topbox, and I have some spanners and screwdrivers. So is it do-able?
Offline SuzukiSte
Re: Heed crash bars and skid plate
« Reply #1 on: March 10, 2017, 11:40:40 »
You need a good socket set and take your time. :thumb:
Offline Stonec0ld
  • Bike: DL650A L5
« Reply #2 on: March 10, 2017, 13:04:55 »
I have an average socket set and limited patience, but I'm encouraged by your response!
Thanks!
Offline King Orry
  • Bike: Glee
« Reply #3 on: March 10, 2017, 17:17:09 »
Read the instructions, then read them again, loosely fit everything to make sure they're where they should be, then tighten. Then go round it again to check you've tightened everything.  :fix:
Finally.. make sure you never fall off and need them. ;-)
Luckily I never fall off..  :happydance:
Offline sirkitchalott
« Reply #4 on: March 11, 2017, 09:42:16 »
Fitted at Xmas, easy enough and like the chap above says, don't rush.
Leave bolts loose as possible before tightening
KE125, RXS100, X7 250, GPX 750R F2, ,GSX400F, Z750, VN900, PAN1300, DL1000
Offline Stonec0ld
  • Bike: DL650A L5
« Reply #5 on: March 11, 2017, 17:02:23 »
Cool, I feel like it's not something I can mess up too bad.
Am I supposed to use locktite or is that not something people tend to bother with?
Offline SuzukiSte
« Reply #6 on: March 11, 2017, 17:20:07 »
You should not need locktite nuts are nyloc one's just use copper slip on them and make sure they are tight. :thumb:
