Author Topic: Caliper Bolts  (Read 1879 times)
Caliper Bolts
« on: March 09, 2017, 20:16:57 »
Are the bolts that hold our Calipers on anything special in terms of their strength? I want to replace mine with Stainless.
Re: Caliper Bolts
« Reply #1 on: March 09, 2017, 20:26:19 »
I'd wondered about this. I would probably expect them to be high tensile but don't know. If you can get exact replacements I.e. precise length of thread, length of shoulder etc. I'd say the size is overkill so stainless should be fine. Cue tales of overheating brittle stainless screws.....
Re: Caliper Bolts
« Reply #2 on: March 09, 2017, 21:11:04 »
See the chart at https://www.boltdepot.com/fastener-information/materials-and-grades/bolt-grade-chart.aspx
The stock bolts are metric 8.8 or SAE grade 5. They are much stronger than stainless alloys. I wouldn't recommend the change. If you do, check them at least yearly.
Re: Caliper Bolts
« Reply #3 on: March 09, 2017, 21:17:45 »
 :thumb:
Re: Caliper Bolts
« Reply #4 on: March 09, 2017, 21:20:03 »
Cheers, GW.
Offline obalanga
  • Bike: DL650 K8
Re: Caliper Bolts
« Reply #5 on: March 10, 2017, 09:49:53 »
I did get myself some replacement stainless steel caliper bolts from wemoto. I can only assume they are up to the job otherwise they would not sell them. They were too long though so I shored them up wit three washers each
Offline Scorgie88
Re: Caliper Bolts
« Reply #6 on: March 10, 2017, 11:34:54 »
Hi blokes, sorry to hijack the post but it seems related so here goes. My front right caliper fell off yesterday. Seems both bolts had worked themselves loose. My own fault for not checking regularly enough I know. The issue I'm having is finding the right sized bolts to replace them with. I bought a set of 4 titanium ones off of ebay but when I put them on they were pressing up against the disc. Do you know if the ABS version has shorter ones? If so, ány idea where I can get some? Cheers.
Offline 500mg
  • Bike: 2011 DL650 AL1
Re: Caliper Bolts
« Reply #7 on: March 10, 2017, 14:01:52 »
I had exactly the same happen to me.  Ordered the bolts from a local dealer and they never turned up.
Ordered from here and delivered within a few days:
https://www.ajsutton.co.uk/spares/chooseModel.asp?make=Suzuki&uID=0
Search for your particular bike and follow the links.
 :thumb:
Offline Scorgie88
Re: Caliper Bolts
« Reply #8 on: March 11, 2017, 01:24:21 »
Top man thanks very much. That's a scary moment though right? I'll definitely be loctiting them on this time!
