Author Topic: Hydraulic Clutch leak  (Read 2601 times)
Offline Cefarcat
  • Bike: DL1000 Vstrom Desert
« on: February 18, 2017, 10:36:26 »
Hi All
went out for a spin on the bike yesterday, when I got back and gave the bike a clean and a once over I noticed the Clutch fluid was not showing in the window upon opening the reservoir it was completely empty. looking around I cannot see any leaks so it must be the slave cylinder !!!, has any on else had problems with this and will it be covered under warranty.
Offline Hugh Mungus
  • Bike: Fazer 1000
Re: Hydraulic Clutch leak
« Reply #1 on: February 18, 2017, 20:32:13 »
I've just had this on my V-Strom but mine is a 2008 model and I don't think it was greatly looked after.
I refilled the reservoir and then bled the system to get all the old fluid out. Not had a problem since.
I don't know bugger all about warranties.
Offline Ravetech
  • Bike: 2015 DL1000
« Reply #2 on: March 10, 2017, 05:40:23 »
Just found the same issue with my 2015 DL1000. From other threads I have seen this could be a a common problem. Not sure about warranty and as I am in Thailand I may prefer to do the job myself. Anybody have a part number for the slave cylinder seal and if possible a supplier. Thank's in advance.
Offline wurzel
« Reply #3 on: March 10, 2017, 06:43:51 »
Ravetech, if you struggle to find the part there, I will go to my dealer, (decent people), and order what you need and send it out to you.
I don't know the part number,or anything about the issue, but will happily get the parts you need once someone has established what is at fault, probably just a slave cylendar seal kit.
pm me if you get stuck.
Offline Ravetech
  • Bike: 2015 DL1000
« Reply #4 on: March 10, 2017, 07:30:24 »
Cheers Wurzel, that's real decent of you I must say. I have pulled the seal and it is simply worn out. Bike only has 30,000 km so they must  be made of butter. I will see if I can match it with another at the local auto store first. Fingers crossed.
Offline SuzukiSte
« Reply #5 on: March 10, 2017, 11:53:26 »
@Ravetech Hi got the Sat Nav mount fitted spot on thanks. :thumb:
Offline Witches70
  • Bike: 2014 Dl 1000
« Reply #6 on: March 10, 2017, 18:15:50 »
I had this happen to me last year riding round the ring road in Rotterdam , what a complete shit . Had to pull in to a petrol station and by some dot4 and fill my reservoir up but a waste of time as the seal had one seated it self and it leaked like dear lizzers bucket . Called breakdown and was taken to a Suzuki dealer in Lidden Holland , he repaired it for 20 euros and it's still holding .
I did get it checked out by my dealer when I got home and all is fine . A common fault so I have been told ???  :thumb:
I stand tall,  but I am short
I shout loud, but I am quiet
I ride a DL1000 and Proud.
Offline Ravetech
  • Bike: 2015 DL1000
« Reply #7 on: March 11, 2017, 03:26:23 »
Found the part number and it is the same as the busa on fleebay. Order placed just in case I can't find one locally then at least I know this one is on the way.
http://www.ebay.com/itm/221717201118?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Well done DLste.  :thumb:
