Author Topic: Dealer mode connector on 2014 V Strom 1000  (Read 4681 times)
Offline Cobby
« on: February 13, 2017, 09:22:52 »
Morning,
In an earlier post I mentioned my bikes FI light came on during a ride, a very wet ride I hasten to add, and it put itself into limp mode. The fault was rectified by turning the bike off then back on again but I wanted to know what error code was stored in the ECU. Going off advice and photos on this forum I decided to put the bike in dealer mode to read the fault code but can I heck find the dealer connector under my seat. See picture.
Can anyone point me in the right direction please?
Offline Sam
Re: Dealer mode connector on 2014 V Strom 1000
« Reply #1 on: February 13, 2017, 09:50:33 »
Putting your bike in dealer mode will only show active error codes, it won't show stored codes. If you've managed to clear the FI light it won't show anything. Only a main dealer can read stored codes.
« Reply #2 on: February 13, 2017, 14:24:30 »
You need a Suzuki SDS tool or a HealTech Suzuki OBD tool to read a stored code. If you are worried about it happening again, carry your spare key and a bit of wire or a paper clip with you so you can get under the seat and put the bike in dealer mode if needed. http://www.vstrom.info/Smf/index.php/topic,7061.0.html
Your dealer mode coupler is #15 in the picture. Again, you have to have an active FI to read a code from it without a special tool and a computer.
