As a tip to starting your bike, the mechanic showed me how to crank the bike with reduced battery power. Place the bike in neutral, hold the engine starter button in and then turn the ignition on. this stops the headlights coming on when you first turn the ignition on. Simply pull the clutch lever in and bike should start. It worked for mine when the stator wasn't charging the battery.
