Author Topic: Fork oil replacement - has anyone drilled and tapped the lower legs?  (Read 2210 times)
Offline locksim
  • Bike: DL650 AL8
Hi all,
Poor show having to dismantle each time you replace the fork oil - has anyone tapped and fitted a drain bolt to each lower leg and fancy sharing the techniques/pitfalls to avoid?
Cheers,
Simon
Re: Fork oil replacement - has anyone drilled and tapped the lower legs?
« Reply #1 on: February 05, 2017, 12:09:36 »
The tricky part would be to machine the flat that the screw head and gasket would fit. Drilling and tapping would be pretty easy in comparison. A possible alternative would be a tapered pipe plug that wouldn't require a machined flat. Then the trick would be to make sure there is enough meat to hold it. It might be better to add a little weld to build up the area.
Offline plumber02
  • Bike: DL1000-K8 wr450f
« Reply #2 on: February 05, 2017, 16:55:18 »
just use a vac pump n suck it out , that's what I used when trying to get my oil weight right
Offline locksim
  • Bike: DL650 AL8
« Reply #3 on: February 06, 2017, 06:35:54 »
Plumber02- got a link to a vac pump that'll do that? Sounds ideal!
Simon
Offline Sam
« Reply #4 on: February 06, 2017, 08:55:33 »
I just used a large syringe with a piece of pipe fitted to it.
Plenty on ebay for a couple of quid.
Offline WayneS
« Reply #5 on: February 06, 2017, 11:39:49 »
I have always used a Pela 650, because I already have one, and it comes with some different diameter plastic pipes which always seem to do the job. I also use it for the lawnmower, boat engine, car and the bike oil change (I had a nasty time with a with a previous owner over tightening a sump plug and stripping the thread. I do not want to go there again).
Offline ziggy
« Reply #6 on: February 06, 2017, 12:20:02 »
Stripping is a pain but blimey how often do we change the oil?
Offline locksim
  • Bike: DL650 AL8
« Reply #7 on: February 06, 2017, 20:00:34 »
Yeah, I hear you - strip it is. I was just being lazy. After selling my classic bikes I didn't want to face more spannering but it's no big deal!
Simon
Offline plumber02
« Reply #8 on: February 06, 2017, 21:08:40 »
one of these is what I used with an old damper rod just for rigidity , surely someone you know will have one , even if you have a brake bleeder vac pump its the same thing that's what we use to get the air gap right
