Handguard Repair Advice
Topic: Handguard Repair Advice (Read 2974 times)
mbpdavies
Bike: DL650 K7, CBF125
January 29, 2017, 16:51:19 »
Evening All,
Got myself into a needless situation today on an icy/snowy lane and ended up dropping my bike at a standstill on it's right side. Thankfully the crash bars did an excellent job, the only damage being a smashed front indicator and cracked hand guard. Luckily some mountain bikers helped me to lift the bike and push me up the hill!!
Anyhow... The hand guard has sheared off where the top fixing point is, it looks like it would glue together nicely. Does anyone have a recommendation for a product that would bond this type of plastic?
The indicator is going to need replacing, hopefully they're not too dear.
Many thanks
Flanners
Bike: 15 DL1000 99 Daytona 955i 05 GSXR1000
Re: Handguard Repair Advice
January 29, 2017, 17:22:05 »
For the money I would source a secondhand one on ebay or buy a new one, given that it will be weaker the next time you drop it and aesthetically won't look good glued that's if you can glue them.
mbpdavies
January 29, 2017, 17:40:17 »
It's only broken in one place so would really like to have a go at repairing it, I will have a look at second hand though, a new pair is £60!
Fat Rat
Administrator
Bloke/Geezer/Fella
January 29, 2017, 17:46:04 »
Araldite is always my first choice
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
UK_Vstrom650
Bike: DL650A L2
January 29, 2017, 18:00:38 »
I read somewhere (
Ride
magazine?) that to repair cracks in panels you can melt zip ties into the hole/joint as it's made from the same material (like welding the plastic). Not sure if it'll work on handguards & never tried that technique myself...
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #5 on:
January 29, 2017, 18:07:11 »
It does work, just don't breathe in.
Visit the
V-Strom.co.uk shop
today!
Hugh Mungus
Bike: Fazer 1000
Reply #6 on:
January 29, 2017, 21:06:10 »
Great video.
You could also try some 'Pipeweld' glue - (not sure if that's its proper name) and if that doesn't work try the soldering technique.
mbpdavies
Reply #7 on:
January 29, 2017, 21:07:07 »
Thanks for all the suggestions, the broken piece is a bit small to try the welding so will give a two part epoxy type thing a go. Will report back later this week...
AZ Pete
Reply #8 on:
January 29, 2017, 21:55:02 »
Did the same thing to my Vstrom hand guard. Tried plastic welding, too thin. Tried one part plastic glue....worked for a week or so. Then was recommended Locktite Plastics Bonding System. It is a few ounces of liquid super glue in a tube and a primer solution in a felt tip applicator. All for about three dollars. It worked like a charm and has made a strong bond for over a year now.
pb
Bike: V Strom 650 2015 in blue
Reply #9 on:
January 30, 2017, 10:17:16 »
I did the same thing to the hand guard. Used the fixing glue for kitchen light pelmet and fitting, two part glue , one normal glue container and then an aerosol to activate, very controllable and no mess, worked a treat and you can't see the join.
AZ Pete
Reply #10 on:
February 17, 2017, 12:58:03 »
Did you get your hand guard fixed??
mbpdavies
Reply #11 on:
February 18, 2017, 15:45:52 »
I did Pete, sorry for not posting. I found some of the loctite plastics glue as recommended and it's done a great job. I even managed to save the indicator housing, in the end all that was needed was a new bulb and replacement lens
