Author Topic: Front mudguard extender  (Read 5110 times)
Offline Ian Cotterill
  • Bike: DL650 L6
« on: January 05, 2017, 21:35:31 »
Hi. Just got my new strom and want to know if there is a good front mud guard extension to help stop bottom end getting battered
Re: Front mudguard extender
« Reply #1 on: January 05, 2017, 22:27:14 »
I used a product from Pyramid Plastics. https://www.pyramid-plastics.co.uk/categories.html?catnum=14&dept=Suzuki%20Motorcycle%20Accessories
The Americanism filter won't let me post the name here but it starts with Extenda and doesn't end with mudguard. It looks a bit like F*E*N*D*A. It looks to be a UK product too but this site objects to the product name as being too American.
Online chris1200
  • Bike: 2008 V Strom 650.
« Reply #2 on: January 05, 2017, 22:41:28 »
It is indeed an Extender mudguard and I have one on my bike. In fact I always buy one from them for any bike I buy. Just fit it as recommended and it will do a fine job.
Offline SuzukiSte
« Reply #3 on: January 05, 2017, 22:59:59 »
Got one on mine it's the first part I put on any bike I have saves a lot of muck getting on them header's.????
Offline pb
« Reply #4 on: January 06, 2017, 11:57:05 »
Hi
I ordered this one off fleebay last year, (Suzuki DL650 V-Strom 2012> Extenda mudguard by Pyramid mudguard Extender 050300)
about £17 and really easy to fit, keeps all the muck off the bottom of the engine, no screws or plastic clips, just use a good quality waterproof glue not the double sided tape it comes with.
Online Fat Rat
« Reply #5 on: January 06, 2017, 15:12:07 »
Online Fat Rat
« Reply #6 on: January 06, 2017, 15:13:21 »
Quite right too. I'm fighting for English independence :smirk:
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #7 on: January 06, 2017, 16:09:26 »
I was looking at these too after seeing the crap on my pipes after a wet weather ride. I was wondering if the tape would be strong enough as other types looked like the bolted on and I didn't fancy drilling holes.
Offline SuzukiSte
« Reply #8 on: January 06, 2017, 16:34:18 »
Holes are easy just get a 4mm drill bit and use a small block of wood between the mudguard and tyre a lot better than tape and miles better than removing the mudguard.
Offline SuzukiSte
« Reply #9 on: January 06, 2017, 16:36:07 »
#fat rat mudguard what mudguard thought that was a musical instrument. lol
Offline SuzukiSte
« Reply #10 on: January 06, 2017, 16:36:54 »
See what you mean now ????????
Offline doboy
  • Bike: 1050 v strom
« Reply #11 on: January 06, 2017, 17:49:33 »
DLste +1
« Reply #12 on: January 06, 2017, 18:58:42 »
The tape the thing comes with is just for positioning purposes. I took it off and added 3M permanent, double sided foam tape to fill great majority of available space. I found that allowed dirty water to drip down from the small spaces between Extenda and mudguard after accumulating there and affect the appearance. I used some black silicone seal all around the margins to prevent that. The Extendas I added have been on a Wee for over 120,000 miles and a Glee for over 17,000 miles with no problems. ABS cleaner then cement works too. The Extenda I first installed on the Wee with the temporary tape and sheet metal screws came loose.
Offline Angustoyou
  • Bike: 2013 Glee
« Reply #13 on: January 07, 2017, 19:59:39 »
Mine came with a pyramid plastics extender fitted.  Does the job nicely, and there are no screws on mine.  Don't know if the po just used the supplied foam double sided sticky stuff or went for domething stronger.  No signs of anything else used. Whatever, it is doing the job.
« Reply #14 on: January 07, 2017, 20:47:40 »
Mine got screwed on after it tried to escape at 70mph on the M1. Used the 3 screws, pipe solvent and some black sealant too. That bugger isn't going anywhere!!!
Offline matchless
  • Bike: Moto Guzzi V7 850
« Reply #15 on: January 08, 2017, 13:57:51 »
Have fitted extenders just using a good coating of silicone sealer to my bike's ,never had one fall off yet.
"It may be rubbish, but it's British rubbish !"
Offline Moo
« Reply #16 on: January 08, 2017, 14:49:18 »
I also run with a rubber flap attached to the bottom of the extender. Get absolutely no splash off the front wheel  :lala:
Offline Flanners
« Reply #17 on: January 16, 2017, 07:48:05 »
I bought some of that mix your own epoxy resin type adhesive from Poundland for a nugget and it has kept my Extenda on for 2 years off road and through the odd Summer monsoon, the double sided adhesive pads don't hold it as mine fell off in Honfleur, luckily I heard it go and a kind French person picked it up for me.
« Reply #18 on: January 16, 2017, 09:19:40 »
My "Pyramid" extender instructions show that the tape is for positioning only. It also has four plastic rivets and drilling instructions.
