DL1000 K8 Brake Upgrade
Topic: DL1000 K8 Brake Upgrade (Read 1068 times)
chrisdibber
Shit Happens
Bike: DL 1000 k9, bmw f650st,
December 29, 2016, 10:18:13 »
I Have just fitted a pair of TOKICO 4 pot calipers from a GSX600, and added HEL braided hose's, and Scandinavian Brake pads, should I go the "Whole Hog" and replace the master cylinder, or will the standard master cylinder do?
sv1000
Bike: DL650 L5, GS550
Re: DL1000 K8 Brake Upgrade
December 29, 2016, 18:50:08 »
I have fitted the same 4 pots along with an 1 5/8" master cyl (14mm is standard) off an sv1000. these along with brembo red pads will transform your braking.
Hugh Mungus
Bike: Fazer 1000
December 29, 2016, 20:43:05 »
I fitted 4 pots off a Honda Hornet & HEL lines. So far I have kept the standard master cylinder and I'm OK with it, I did wonder whether a different m/c would make a big enough difference to bother.
