Author Topic: Rattle rattle rattle  (Read 3651 times)
Offline vstromspoon
  • Bike: Suzuki VStrom 1000 2014
« on: November 29, 2016, 09:05:39 »
I've noticed latly I'm getting a rattle from low acceleration. It sounds like its coming from the chain but I could be wrong. Can the chain rattle if it's too loose?
Old bikes
1997 gsxr 600 srad
1999 cbr 600f
1999 Yamaha r1
2006 gsxr 750
2014 gsxr 1000
Offline Hondaman
  • Bike: 650 L3
Re: Rattle rattle rattle
« Reply #1 on: November 29, 2016, 10:27:49 »
They can rattle & clunk when worn irrespective of wether the adjustment is correct.
Offline grumps
« Reply #2 on: November 29, 2016, 12:15:03 »
Loose front sprocket?
« Reply #3 on: November 29, 2016, 16:50:29 »
Knackered or badly adjusted chain is favourite. Ditto worn sprockets.
Sent using carrier pigeon...
« Reply #4 on: November 29, 2016, 18:11:31 »
If you suspect the drive chain is too slack also check the plastic swing arm protector for excessive wear.
Offline vstromspoon
« Reply #5 on: November 29, 2016, 18:59:18 »
It is a bit loose but nothing too much. I've had worse in the past. I've done 14k on it now so would they be worn out at that sort of miles?
Old bikes
1997 gsxr 600 srad
1999 cbr 600f
1999 Yamaha r1
2006 gsxr 750
2014 gsxr 1000
« Reply #6 on: November 29, 2016, 22:18:47 »
I examine the chain for wear to or missing, 'O' rings and the amount off side slack and the amount of adjustment already taken up.
I would check the sprockets and if either or both is worn replace the lot.
If the sprockets are OK I would run the chain until they need to be replaced.
Offline vstromspoon
« Reply #7 on: December 03, 2016, 15:02:01 »
Been to my local Suzuki dealer in lincoln and got them to have a look. The chain was about touching the floor so I don't think that was very good lol. But its been nipped up and is due a new chain and sprockets so its going to be a nice big bill next time I go there as its due a 15k service to.
Old bikes
1997 gsxr 600 srad
1999 cbr 600f
1999 Yamaha r1
2006 gsxr 750
2014 gsxr 1000
tychris523
« Reply #8 on: December 03, 2016, 16:00:15 »
Geez you have had all those bikes you have listed and you didn't check or even look at the chain you need some basic motorbike education
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #9 on: December 03, 2016, 17:52:38 »
Erm. If you've had worse in the past then I can only wonder at how bad they were. If you get the spanners out and keep it adjusted, not forgetting some chain lube every now and then, you could save a whole load of money  :fix:
Offline Joe Rocket
« Reply #10 on: December 03, 2016, 19:41:42 »
What they all said!  :shock:
 :icon_wink:
« Reply #11 on: December 03, 2016, 21:01:10 »
OK folks, so the fella missed out on some basic maintenance, this place is to help others not take the piss.
« Reply #12 on: December 03, 2016, 21:02:47 »
Bit early for new year resolution innit?
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #13 on: December 03, 2016, 21:06:00 »
I'm not taking the pee (well maybe a bit) but we all need to start somewhere and if vstromspoon needs some advice/help I will gladly give it. I'm only an hours ride away.
« Reply #14 on: December 03, 2016, 21:07:06 »
Better  :thumb:
Offline vstromspoon
« Reply #15 on: December 04, 2016, 06:16:42 »
lol don't worry I deserve it nothing wrong with some pee taking. to be honest it really didn't look that bad to me. I do know how to adjust them but the garage does it for free so I can keep my hand clean  :lala:
And I don't lube it every week. I'm pritty sure 15k out of a chain isn't to bad anyway is it?
Old bikes
1997 gsxr 600 srad
1999 cbr 600f
1999 Yamaha r1
2006 gsxr 750
2014 gsxr 1000
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #16 on: December 04, 2016, 06:23:36 »
I would expect a lot more than 15k but it does also depend on how hard you accelerate. Lubing the chain regularly does make a difference. If you're happy with the expense then it doesn't matter.
I tend to wear my tyres quite quickly compared to other riders I know but having seen the way they ride I am more than happy to carry on enjoying myself and just buy more tyres.
