Author Topic: Wrong speedo reading  (Read 1206 times)
Offline Iowvicar
  • Bike: V Strom 1000
« on: November 26, 2016, 22:19:19 »
Just brought a 1000 today and have discovered that the speedo is ready 10 mph faster than the car is car 70 bike 80 car 80 bike 90 is this normal or can the speedo be adjusted to read correct
Offline chris1200
  • Bike: 2008 V Strom 650.
Re: Wrong speedo reading
« Reply #1 on: November 26, 2016, 22:26:58 »
Check your Sat Nav speed. All speedo's are out as a matter of course, as your cars will be.
« Reply #2 on: November 27, 2016, 00:57:28 »
Around 8% fast is typical. Do you have a first or second generation 1000, Vee or Veek according to my sig? There are plug and play solutions like the HealTech Speedohealer and the 12oclock labs SpeedoDRD that interrupt the signal and adjust it as needed. The Vee units are available as plug and play kits while the Veek needs a universal model that requires some cutting and splicing. The Veek doesn't have a dedicated speed sensor but interpolates speed from the ABS sensors and doesn't run the speed signal, power and earth wires through the same connector. Be aware if you install such a unit, the normally ~2% high odometer will read lower than actual mileage.
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #3 on: November 27, 2016, 14:00:33 »
If the sprocket sizes have been changed it can affect the speedo. Easy enough to check by looking for the sprocket size stamp or counting the amount of teeth.
So check the speedo against a sat-nav as Chris says and then follow Greywolf's suggestions.
« Reply #4 on: November 27, 2016, 16:18:43 »
A sprocket change will make a difference on a Vee or a Glee but not on a Veek or a Wee.
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #5 on: November 27, 2016, 17:02:13 »
Worth noting Greywolf  :thumb:
