Is rust inside handlebars normal?
Topic: Is rust inside handlebars normal? (Read 1218 times)
mrp192
Bike: V-Strom 1050
November 20, 2016, 22:53:50 »
I had the bar ends on my 2015 Glee off today and the clutch side had a dry rusty surface on the internal spacers and this was also on the internal surface of the bars.
Only surface rust but the throttle side was unmarked and came out a lot easier.
I've cleaned it off but obviously can't lubricate it on reassembly and can't work out how it got wet.
Has anyone else had this?
Offtheclockuk
Bike: DL1000 K2
Re: Is rust inside handlebars normal?
November 21, 2016, 07:06:54 »
My 02 vee was the same, just a light dusting almost.
Guess it must be normal for bikes that see wet weather use?
mrp192
Bike: V-Strom 1050
November 21, 2016, 10:05:38 »
'A light dusting describes it perfectly.' I was just worried that if other older bikes had the same but getting worse over time it might weaken the handlebar.
Offtheclockuk
Bike: DL1000 K2
November 21, 2016, 14:55:40 »
I'm guessing as the bike leans over on the side stand with the steering lock on that the clutch side is the lowest point and water will naturally collect around there.
StromGeeza
Global Moderator
Bike: just scoots now
November 21, 2016, 17:32:56 »
Squirt some acf50 down there?
mrp192
Bike: V-Strom 1050
Reply #5 on:
November 21, 2016, 18:57:44 »
I've never used ACF50 before. Would that not stop the bar ends gripping properly?
StromGeeza
Global Moderator
Reply #6 on:
November 22, 2016, 09:26:54 »
I doubt it, but if you're worried about that just don't spray the very ends.
ACF is good stuff for other places on your bike besides, especially now winter's here.
