Hello blokes,
After a little advice/opinions please.
Its time for me to change my change and sprockets, currently OEM and have seen about 22.5k miles (done well I think).
I would like to increase the front sprocket up a tooth, from 15 to 16, as I do about 2000 miles a month and its normally motorway/dual carriageways so thinking it would make it a bit nicer for cruising.
However I'm not sure that I can find a 16 tooth front sprocket that is dampened like the OEM one.
Normally I would pick JT sprockets and a DID Chain. Still will go for a DID Chain, and most likely a JT rear.
Any ideas if I can get a dampened 16 tooth sprocket, or any other suggestions would be great
Thanks
