Reluctant to rev?
Topic: Reluctant to rev? (Read 2908 times)
Dave L
The older I get the faster I was......
Bike: DL650 AM3
Reluctant to rev?
November 12, 2016, 06:47:28 »
Hi,
I have a K15 DL650 purchased new. It currently has around 7000 miles on it. The bike is very reliable and runs well. However I have noticed that for some reason or another it seems reluctant to rev above 6000 rpm. When the throttle is opened the engine will run up to 6000 rpm without an issue but seems to struggle to rev any higher. My old K6 SV 650S would easily spin up to 8000 without a fuss. I have fitted the bike with a K&N Air filter in the hope that this would help, but it has not.
When I mentioned this to my dealer (Haslemere Motorcycles in Borden) when the bike was serviced recently they told me that all was fine and that all I needed to do was hold the engine in a lower gear to get it to rev.
Has any one else come across this?
TLPower
Bike: ThunderBastard (KTM 1190 ADV)
Re: Reluctant to rev?
November 12, 2016, 06:58:19 »
Does it have the restricted ECU
SuzukiSte
November 12, 2016, 08:34:13 »
Same as TL Power said sounds like my mates he had a restricted ECU same thing takes bike to 47 BHP instead of 68 BHP.
Dave L
Bike: DL650 AM3
November 12, 2016, 09:07:22 »
Hi,
I am not aware that it has a restricted ECU, it should not have as I have a full UK licence and this was not mentioned when I purchased the bike. Other than a dyno check, how else will I know if the ECU has been restricted?
MartinW
Administrator
Bike: DL650 K4 Blue
November 12, 2016, 09:29:23 »
There is a different code printed on the restricted ECU. They are on here somewhere.
Post the code of yours and we can check.
Hondaman
Bike: 650 L3
Reply #5 on:
November 12, 2016, 09:42:17 »
As above, something's definately not right.
At 6k they are just nicely getting into their stride & pull strongly up to about 9k (then tail off a bit)
Did you buy it new/pre reg from a dealer or private.
If a dealer, pop back and they should sort it to stock speck foc
Dave L
Bike: DL650 AM3
Reply #6 on:
November 12, 2016, 11:32:24 »
Hi,
I bought the bike new, and it was registered only after I signed the purchase agreement. When I mentioned the issue at the last service the dealer told me that "all was OK".
The code on the ECU is: 11J90; MGT 219; F8T54180; 4526
UK_Vstrom650
Bike: DL650A L2
Reply #7 on:
November 12, 2016, 11:46:00 »
I'm assuming your issue is in all gears? If it helps I can hit hit 60mph in second gear if needed and it pulls like a train straight through the rev range. If yours can't and/or is struggling beyond 6,000 rpm then you need to go back to the dealer.
AlanT
Bike: DL650A L4
Reply #8 on:
November 12, 2016, 13:52:58 »
The full ECU part number appears to be 3292011J90. The 11J90 on yours suggests it is the standard one.
greywolf
Reply #9 on:
November 12, 2016, 14:15:34 »
The usual problem in such a situation is a clogged high pressure fuel filter in the fuel pump on a bike having seen long use. Yours is a new bike though. Take it back. It should have much more power over 6000rpm. BTW, it is an L5, not a K15.
http://www.vstrom.info/Smf/index.php/topic,11834.0.html
650XT Pete
Bike: DL650XT
Reply #10 on:
November 17, 2016, 20:59:02 »
Dave L , did you sort out the problem with your bike not revving up. Just interested in the outcome.
Never ride faster than your guardian angel can fly.
Dave L
Bike: DL650 AM3
Reply #11 on:
November 19, 2016, 20:44:07 »
Hi,
Not sorted the issue yet as I am away on business. Once home in December I will ask to take a demo DL for a ride to compare and then will ask the dealership to take my bike for a ride. Previously I was told that "all was OK" but I am not convinced.
Reluctant to rev?
