Sorry Rat, I ordered from them, and all I did to ensure lines fitted was state I wanted them 25mm longer than standard, no extra charge, supplied with every thing except fluid to install, fitted OK. ( but I take your point that some people have had a problem with them not supplying the correct length lines).
I still found that drawing the fluid down the lines with a syringe helped easy bleeding.
