Author Topic: Best place to get a switched live feed for LED fog lights  (Read 2597 times)
Offline Turtleossie
  • 46 + 58 = ??
  • Bike: Owt ????
« on: September 15, 2016, 19:38:08 »
I'm wiring in some LED fog lights via a handlebar switch, just wondering where around the bars is best to pick up a switched live feed, always on when bike is on?
2006 VEE in case you're wondering...
If you help I promise to take pics when finished ????
I am a qualified electrician so just need where and wire colour thanks!
Ride bikes, drink beer, eat chips.
Re: Best place to get a switched live feed for LED fog lights
« Reply #1 on: September 15, 2016, 20:45:01 »
Why not get yourself one of these  then run a cable from there. Plus a couple more fused outlets for more goodies!!
http://www.v-strom.co.uk/smf/index.php?topic=24607.0
Just used mine to rewire my spots & DRL's today.
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #2 on: September 15, 2016, 21:57:21 »
I would wire in an aux fuse box that comes live via a relay. You will get stronger power for your lamps that way.
You can find a switched live at the feed for the brake light switch or the horn, use this to turn on the relay for the aux fuse box.
« Reply #3 on: September 16, 2016, 07:58:48 »
The bigpie fuseboxes have a switching relay fitted. They're a neat easy solution to wiring in extra circuits to the bike.
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #4 on: September 16, 2016, 20:53:36 »
Yes they do look neat and tidy.
Offline boomer
  • Bike: 2014 DL650A L4
« Reply #5 on: September 17, 2016, 11:44:35 »
For an ignition live I used the orange wire on the horn feed.  This is OK for a relay signal or just voltage monitoring,  not sure how much current you could draw from here though. I used it for a voltmeter feed on my 2014 Glee. :fix:
