Only ways to snap one is its worn through dirt constantly hitting at it over the years, replaced my one a while ago because it was worn at the point where the chain is close or you have a seriously loose chain which can hit the push rod .
Not expensive to replace but the best thing to do is replace the push rod seal also .
You need to remove your clutch slave , front sprocket cover and front sprocket in oder to do this job .
