Author Topic: Charging...again?  (Read 6377 times)
Re: Charging...again?
« Reply #20 on: September 09, 2016, 17:24:28 »
Out of interest was it the coils at the top of the stator that were burnt out?
Offline markrob
  • Bike: DL650 L0
« Reply #21 on: September 10, 2016, 19:17:18 »
To Crazy horse
I am still having problems, tested the R/R but not convinced it's at fault, only using the Haynes manual as a guide.
I have tested the alternator (static) all seems fine.
At £215 it's a lot to pay if the R/R is not at fault,
I will keep trying, I bought a Suzuki as they were supposed to be bullet proof, at 6years old & 36000 miles I am beginning to loose faith
Mark
Offline crazyhorse
  • Bike: DL800RE M4
« Reply #22 on: September 10, 2016, 19:49:49 »
Hi
Markrop...My fault on the coils was that one coils was showing a very low voltage.
If you have a voltmeter, and whilst you have the alternator disconnected from the Reg/Rec, start the engine, and with the voltmeter, measure the voltage (on the Volts AC scale) between the three leads from the alternator.
(A to B, A to C and B to C). All readings should be 60vac or above.
This is all with the engine revs at 5k.
If you have already tested the alternator in this fashion, I apologise for wasting your time.
Kwackboy...yes it was at the top of the coils, but at the rear of the unit.
Crazyhorse
Offline crazyhorse
  • Bike: DL800RE M4
« Reply #23 on: September 14, 2016, 22:53:58 »
Hi
Got a Shindengen SH847 series reg/rec, from Jack at Roadstercycle in California.
What with the import tax, and Royal Mail asking for a slice, it was not the cheap option, but I intend to keep the bike for another two years, so thought I'd give the new coils the best of chances to survive longer than the original.
It is physically a larger item, and I am modifiying the bracket the original reg/rec sat upon, but it will fit.
Will do a couple of photos when nearer completion.
Crazyhorse
« Reply #24 on: September 15, 2016, 00:01:14 »
Jack is a good bloke. I'd wire the DC side of the R/R to the battery with an automotive circuit breaker near the positive post.
